Retrieving SQL error variable from ASP
MarkJ
PostPosted: 11:40 - 28 Feb 2011    Post subject: Retrieving SQL error variable from ASP Reply with quote
Morning all,
We're making an ASP website at work which connects to an Oracle SQL database. I've managed to get it to display the data from the table we're using, and input data into the table, however there is no error trapping. My boss has made a SQL package that when run in SQL inserts into the table. When the package is run, the output variable is either an integer if the insert succeded, or a string (saying "error, blah blah blah") if there was an error. This variable is written to dbms_output.
The procedure is as such (I've stripped a few lines out as it's quite long)
Code:
procedure create_gr(p_surname varchar2, p_forename VARCHAR2, p_birth_year INTEGER, .... p_result out VARCHAR2);
This is the actual code executed in the ASP page;
Code:
'Create Connection
SET myConn=SERVER.createobject("adodb.connection")
myConn.Open "DSN=ODBCCONN;"
'Create string with SQL command to run
SQLStr="begin declare v_res varchar2(200); begin gr_package.create_gr('" & strforename & "','" & strsurname & "'," & stryob & .... ,v_res);dbms_output.put_line('the inserted id is '||v_res);end;end;"
Response.Write("SQLStr is " & SQLStr)
Response.Write("<P>New Line Added</P>")
SET result=myConn.execute(SQLStr)
Now if all the code is fine then it inserts fine, but I don't get anything back as it's being written to dbms_output.
It looks to be as though SET is running the SQL command, but is there a way of getting back the variable 'v_res'?
I am an absolute noob when it comes to SQL and ASP. I was pretty good at programming Java when I was at Uni but that was a few years ago.
huskie69
PostPosted: 15:36 - 28 Feb 2011    Post subject: Reply with quote
Not sure if this is any help... I'm an Oracle DBA but have zero experience when it comes to ASP. However, Looking at your code, I would change the dbms_output.put_line calls to utl_file.put_line calls and set up utl_file and open a file first. You'll then need to cat/tail (or whatever Windows alternative you have on the host) the file in another session. Depending on you Oracle version (9.2+), you can use the autoflush option to write to the buffer and immediately flush the contents to the file.
'10 Skyjet SJ125-23 - Crashed Sad > '09 YBR 125 > '53 Suzuki SV650 - Died Sad > 2010 Suzuki VanVan 125 > '87 Yamaha FZ750 Sold > VTR 1000 FireStorm - Sold > Honda CB1000R
supZ
PostPosted: 15:25 - 01 Mar 2011    Post subject: Reply with quote
not sure if i understood your problem, but are you attempting to get details of a sql error in your asp code?
i.e. something in sql causes an error and you want to get it in asp?
if so you can use the Server.GetLastError object to get the aspcode, number, aspdescription, line, etc.. of the error. you can identify from the category if its an asp error or a sql one.
remember you'll need an on error resume next and and err > 0 catch to deal with it.
there should be plenty of info on the object and error handling in asp on google.
hope that helps
CBR954RR - Daily toy
CBR600RR - Trackbike
The last post was made 15 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 38.48 Kb
