Wiring things into the car
Phil.
PostPosted: 13:42 - 01 Mar 2011    Post subject: Wiring things into the car Reply with quote
I just bought a A2DP bluetooth adapter for the car so along with a new tasker profile I should be able to have a play list play automatically when i'm in the car.
I have exactly zero experience with wiring things into cars. The bike has never been an issue, always tapped into the rear light. However I don't know where to start with a car.
My first thought was the cigarette lighter but that seems to be live when the ignition is off.
Any pointers on where's a good place to take power from? It's a MK4 Mondeo by the way.
Thanks
PostPosted: 13:53 - 01 Mar 2011    Post subject: Reply with quote
One of the feed wires for the radio is probably live only when the ignition is on (although if I wired it I would have the whole stereo wired to be on whether the ignition is on or off). You should be able to tap into that wire easily (and as a bonus with luck it will be a separate plug in adaptor for the radio rather than a bit of the main loom that you are chopping up).
kingsmith
PostPosted: 13:55 - 01 Mar 2011    Post subject: Reply with quote
you need to find a live when the ignition is on prob from the live feed from the radio, or try find a spare unused fuse holder in the fuse panel they usualy have one spare..
then wire it all in and make sure where ever you take it from you get a in line fuse in place just in case....
and if you not that compitant get some one round (mate ) who knows what to do..
its not that hard , when you look it it.
all the best
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
UnknownStuntm...
PostPosted: 16:12 - 01 Mar 2011    Post subject: Reply with quote
Ford certainly used to adhere to the ISO wiring, where the switched live for accessories including radio equipment is yellow. If you can, pull the stereo out and have a look for a connector behind there. There will most likely be a couple of wires thicker than the rest, a brown (earth) and a yellow (switched live).
Sony were among manufacturers who didn't like yellow for this, they liked red. So be on the lookout for a red one too - might even have a connector to allow you to swap the red and yellow over.
Anyhow, use a circuit tester on the combination of red, yellow and brown to get the right cable then solder in to this. Put a fuse in too. Oh, and take the negative lead off the battery while you're soldering.
The last post was made 15 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 41.58 Kb
