R1 coolant
gray84
PostPosted: 18:06 - 02 Mar 2011    Post subject: R1 coolant Reply with quote
just fitted my new radiator and ive got the correct colour coolant. is 1 litre enough? its from concentrate so i presume its 50/50 ish
how do i bleed the system when i fill it up?
thanks
gray
0l0dom0l0
PostPosted: 18:13 - 02 Mar 2011    Post subject: Reply with quote
1 Litre won't be enough. My Fazers takes 2L (in total) and the rad on that is tiny. I would suspect atleast 3.5l, if not 4L.
50/50 sounds good. Make sure you use distilled water, or de-ionised or whatever it is. Tap water is full of to much crap.
I have never needed to 'bleed' the Fazer. Just filled it up very slowly, and squeezed any exposed pipes in the process. Start her up, leave for a bit then check the level and top up if necessary.
Hope that helps.
gray84
PostPosted: 18:17 - 02 Mar 2011    Post subject: Reply with quote
ok then.ill have a hunt on how much the system holds..
PostPosted: 18:31 - 02 Mar 2011    Post subject: Reply with quote
Does colour matter? Read the bottle it will tell you if it needs to be diluted, there will be a screw on the water pump housing start the bike and open the screw, wait till a constant stream of water is coming out.
gray84
PostPosted: 18:58 - 02 Mar 2011    Post subject: Reply with quote
ok in total it all holds 3lts of coolant. so will i be ok with one litre of antifreeze? or should i really go and get another 500ml? Confused
0l0dom0l0
PostPosted: 19:01 - 02 Mar 2011    Post subject: Reply with quote
Have a look on the back and it will tell you about the ratio's and what the minimum temperatures are.
You should be okay with just the 1l, but please check as I don't want to be responsible if you crack your engine block because the coolant has frozen! Laughing
Bloggsy
PostPosted: 19:47 - 02 Mar 2011    Post subject: Reply with quote
get another 5000ml, coolant should be 50/50 antifreeze and distilled water
gray84
PostPosted: 23:27 - 02 Mar 2011    Post subject: Reply with quote
why do i have the fill up cap on the radiator and on the header tank? sorry fro the stupid question but i just looked at it and couldnt figure out why they do that?
also which point is best to fill the system up by?
gray84
PostPosted: 00:18 - 03 Mar 2011    Post subject: Reply with quote
thank you chris..... Thumbs Up
PostPosted: 21:13 - 03 Mar 2011    Post subject: Reply with quote
Stop guessing what the ratio should be, look at the sodding bottle. The stuff in my bike said 2:1 is fine for up to -15degrees.
The last post was made 15 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 63.68 Kb
