| hornetmike |
 hornetmike World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 14:53 - 04 Mar 2011 Post subject: Re: which is the best bike engine cleaner |
| miketovey wrote: | I wanna give my engine a real good clean as it has ground in dirt in lots of hard to get places, what should I use ? I have seen gunk and SC100 , they any good? |
I use a range of things to clean oily stuff, I am also a tight arse so use the cheap stuff when I can, below is what I would use. Gunk is ok, have only tried the aerosol version though so I have no experience of the liquid form and imo it is just a basic solvent in a fancy can at silly prices.
I generally use parraffin to soften and loosen thick oily crud, does a good job and is very cheap (£5 for 4L at B+Q, homebase and now even my local asda), apply it with a stiff brush and work it in the grooves. If you use paraffin, whilst it does a good job of loosening things it is oily in itself so must be washed off afterwards, soapy water will work but I usually have a few cans of cheap brake cleaner knocking around which works well at removing the paraffin in a few squirts.
If you are outside with minimal risk of ignition/headaches then petrol makes a brilliant oil and grease solvent.
You will undoubtedly have lots of non oil based muck on the engine too (mud, salt, grit corrosion etc) that refuse to come off with soap and water and degreasers, for these it depends on what the outside surface of your engine is like. If it is painted then a stiff nylon brush will remove the worst of it, if it is bare alloy then a brass wire brush should get the majority of crud off without scratching the surface. |
| 27cows |
 27cows World Chat Champion
 Posted: 15:42 - 04 Mar 2011 Post subject: |
People clean their engines?  ____________________ The RXS100: vehicle of choice for Chuck Norris |
| Frost |
 Frost World Chat Champion
| 27cows |
| 0ddball |
 0ddball World Chat Champion
| james1988 |
 james1988 World Chat Champion
| Marmalade |
 Marmalade World Chat Champion
 Posted: 17:38 - 04 Mar 2011 Post subject: |
acid, spray it all over, avoid direct sunlight and jet wash it off before it dries, or melts the casings.
Or you could cover it in 'gunk' use a brush to agitate the greasy bits and jet wash it all off after, works for me ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 18:24 - 04 Mar 2011 Post subject: |
I was always curious if there's any issue with getting parrafin, petrol, Gunk or degreaser on the tyres??
I'm always paranoid of getting products on the tyres (particularly the rear) for fear of taking a slide during a corner... ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| Codemonkey |
 Codemonkey Crazy Courier
 Posted: 20:33 - 04 Mar 2011 Post subject: |
Just cleaned my bike's engine which I'd covered in ACF50 before the winter set in. It was pretty filthy, the ACF50 having attracted all of the road crap within a 10 mile radius. I used Gunk green engine cleaner, applied with a paintbrush and then hosed off after 5 or 10 mins and i'm happy with the results. Had to give a couple of applications in some areas but it did the job  |
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 20:36 - 04 Mar 2011 Post subject: |
f it doesn't come of when I use the pressure washer, then the dirt stays on  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| rac3r |
 rac3r World Chat Champion
| Paxovasa |
| pinkyfloyd |
| Paxovasa |
| Shreddie |
 Shreddie Spanner Monkey
| Skynet-T800 |
 Skynet-T800 Renault 5 Driver
| ms51ves3 |
 ms51ves3 Super Spammer
| hornetmike |
The last post was made 15 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
