Mod 1 wipeout
CruiserDreame...
PostPosted: 11:22 - 08 Mar 2011    Post subject: Mod 1 wipeout Reply with quote
Hello all,
Yesterday I did my mod1. All maneuvers were well practiced. Both myself and my instructor were confident I'd pass.
During the avoidance part I came round the curve and accelerated into the straight and found myself looking straight into the early morning sun. I couldn't clearly so I decided to abort and stop.
Unfortunately, I clipped a cone with the front wheel which threw it under the back wheel and flipped the bike out from underneath me.
My kit did its job so I have nothing more than bruises and a few sore spots.
Next time I hope its cloudy.
PostPosted: 11:54 - 08 Mar 2011    Post subject: Reply with quote
Unlucky dude. At least you're still alive and thats the main thing. Good luck next time. Thumbs Up
When I went to walk around the course on my DAS I did shudder when I saw the gouges in the ground from bike spills during the swerve and stop. Shocked
PostPosted: 12:58 - 08 Mar 2011    Post subject: Reply with quote
Ouch. I actually stopped on the way to my Mod 1 to buy some sunglasses. Cool
Well, I think you made the right call, you just got unlucky. I'm glad you walked away from it and I hope it didn't knock your confidence.
Carl_G
PostPosted: 14:31 - 08 Mar 2011    Post subject: Reply with quote
Bloody hell, I'm glad I didn't read this before going to do my Mod 1 today! Surprised
Glad you're ok, which test centre was it? I was worried about how sunny it was today but by my test at 11ish it was fine...
CBT 11/09/10! Theory Passed 12/10/10! Mod 1 Passed 08/03/11! Mod 2 passed 13/04/11!
1993 Yamaha XV 535 (SMIDSYed) 2008 Suzuki GSF 650 (Hire Bike) 1993 Yamaha XV 535 (Resurrected!) 2004 Triumph Speedmaster 790cc (Payout from SMIDSY!)
CruiserDreame...
PostPosted: 19:49 - 08 Mar 2011    Post subject: Reply with quote
Hello Folks,
Thanks for the comments.
My confidence is undamaged. I would have had another go straight away if they would let me. I was able to ride the bike back after the event without problems. It wasn't my bike and I had only been on the road with it an hour. Which probably didn't help.
The site is in Chester and runs roughly east to west. For some reason they do the speed runs west to east. The site is only used in the morning, so I'm told, so it would make sense to set it out the other way round.
It seems odd that the cones are not crushable. If they were then I would not have lost the bike. I didn't come off through harsh braking or loss of balance. I came off because I had lost the contrast in my vision and couldn't see clearly and ran into a robust cone.
At minimum speed, 50 KPH, thats just under 14 Metres per second. The cones are 10 metres away which gives less than a second to react. I went through the gate at 54.
Luck or otherwise I screwed it up. But maybe there are some factors here that should have been considered in the design of the test.
iooi
PostPosted: 21:06 - 08 Mar 2011    Post subject: Re: Mod 1 wipeout Reply with quote
[quote="CruiserDreamerDuring the avoidance part I came round the curve and accelerated into the straight and found myself looking straight into the early morning sun. I couldn't clearly so I decided to abort and stop.
[/quote]
Going to play devils advocate here....
Lucky it was off the road.
Get used to riding and then being unable to see due to the sun.
Part of my commute is into the sun, trouble is its on a stretch of road with a few traffic lights on. Most of the road is uphill, so you get no choice but to look up. or you miss the traffic lights.
So there are things they can't design out. like the sun as it tends to move around a lot.
PostPosted: 21:17 - 08 Mar 2011    Post subject: Reply with quote
As above said. Not being able to see because of the glare from the sun isnt an acceptable excuse. You are expected to be able to ride in all conditions from sunny days to pissing rain. The only time they dont expect you to ride is in snow and icy conditions.
When you get the full license you will experience some of the hardest conditions to ride in at one point or another. Night time in the rain when the glare from oncoming cars is blinding because the headlight is reflected in every droplet of water on your visor.
The worse I have found (apart from that ride to Newbury when I hit snow) is when the sun comes out just after the rain and the glare from the sun is magnified by the glare from the road. Nightmare!
CruiserDreame...
PostPosted: 21:36 - 08 Mar 2011    Post subject: Reply with quote
PinkFloyd: You are are corrcet. But what do you do? You slow slow down and reduce risk as I did. But on the road you wont find plastic cones all over the place that can throw you out.
This is an artificial situation with expected performance limits. In the real world you are thinking about what's in front of you not about the guy behind you with a clipboard and a pen.
PostPosted: 21:42 - 08 Mar 2011    Post subject: Reply with quote
Very true points. And in all honesty I do sympathize with you. But I'd rather be tripped up by a cone then scraped off a car. They are less forgiving.
you have to wait a few days now but get the test rebooked and hopefully you'll be fine.
CruiserDreame...
PostPosted: 22:00 - 08 Mar 2011    Post subject: Reply with quote
Pink floyd: True enough. A car is somewhat larger then a 10" blue cone on a grey/black background, wether or not the car is showing any lights.
This test should not test extremes. If you can't see you slow down. If you slow down you fail. You can't win.
I have ridden in all weathers too, except snow and ice, thats just asking for trouble if you don't have to do it.
I'll do it again in a fortnight and i'll pass even if I have to look at the ground.
PostPosted: 22:28 - 08 Mar 2011    Post subject: Reply with quote
Of course you should slow down if you can't see. The Mod 1 often obliges you to do the exact opposite of what's safe and sensible. What sort of a test is that? Yes, it tests control, but not judgement.
The site sounds bonkers. Might be worth asking the local authority environmental health Nazis to take a look.
Paulington
PostPosted: 00:21 - 09 Mar 2011    Post subject: Reply with quote
To also play the Devil's Advocate...
Rogerborg, if all tests did was test you on your standard riding, i.e. on the road in safe standard conditions and such, what happens when a person DOES pull out on you? If the test was like that, you'd have never experienced that situation or anything like it before, so how could you possibly deal with it? It's much safer to learn on a piece of tarmac with some plastic cones than a solid car at 30mph or above.
If you really hate the sun, get an Iridum visor. I took my test with my iridium visor on, it's totally mirrored so you can't see my face, stops ALL glare and works fantastic as a pair of 'sunglasses'. I refuse to ride without one, they are a godsend.
Shreddie
PostPosted: 00:29 - 09 Mar 2011    Post subject: Reply with quote
But it is easier just to get iridium sunglasses (perhaps like mine) 'cos changing visors is a pain and you'd have to carry a clear one with you if you're planning on riding in dull conditions or in the dark.
Paulington
PostPosted: 01:03 - 09 Mar 2011    Post subject: Reply with quote
Why?
I have ridden for over 2 years with a bright orange iridium visor that is totally mirrored and totally illegal on an illegal (car-racing) helmet and have been stopped by the police many times and even did my test with it on!
It's fine in dull conditions, the only problem is at night when it does limit it a lot but you get used to it, at night I just rode with my visor up, don't ride a lot at night anyway, prefer the car.
Thumbs Up!
Shreddie
PostPosted: 03:01 - 09 Mar 2011    Post subject: Reply with quote
Paulington wrote:
Why?
3 points and £60 fine if you do get done I think. Besides, riding in the dark can be tricky enough without a tinted visor.
PostPosted: 08:22 - 09 Mar 2011    Post subject: Reply with quote
I got a helmet with a flip down visor. Great for sunny days. Thumbs Up
PostPosted: 09:08 - 09 Mar 2011    Post subject: Reply with quote
You can't control the conditions of the test, but the rider should be allowed and expected to ride to the conditions, exactly as per Mod 2. The specific problem is the strict 50kph minimum speed limit on the swerve and stop, which doesn't allow the examiner to use the same subjective judgement that they're expected to use when examining Mod 2.
I did my Mod 2 in the aftermath of a blizzard (that I rode through to get there). If I'd ridden the same way in Mod 2 that I'd have been required to ride Mod 1 if I'd sat it on the same day, I'd expect to have been failed for failing to take into account the riding conditions. Get my point?
Xdwardo500
PostPosted: 10:15 - 09 Mar 2011    Post subject: Reply with quote
Might be worth packing some plastic sunglasses in one of your pockets in case of the sun. I always had a pair during my tests, and on a couple of occasions had to stick them on to reduce the glare.
Lincoln, England
2011 Vespa GTS 300 Super
Riding Since 2011
finger_nails_are_pretty
PostPosted: 10:25 - 09 Mar 2011    Post subject: Reply with quote
Unlucky for the fail, but as others have said, lucky that was off road.
You could have been on a road, with sun glare, and that could have been someones child under your bike if you were to swerve like that.
You should have been prepared and got some adequate glasses for riding in the sun (anti glare etc).
Rogerborg - when did you do your Mod 2? I had mine cancelled due to snow, and they also cancel Mod 1 for snow at the centre I used (November 2010). If they think the weather will mean you cannot perform the correct exercises required, they should cancel the test. We are ALOT more likely to be riding in the sun and rain as opposed to the snow, so test should carry on in these conditions. Especially since a pair of sunglasses would probably have solved this issue.
PostPosted: 17:04 - 09 Mar 2011    Post subject: Reply with quote
Last winter. I called in and they said it was up to me if I wanted to do it, so I manned up. The examiner followed in his car, which was probably pink and playing Liberace.
The fact that sites are cancelling Mod 1s rather than allowing riders to adjust to the conditions pretty much illustrates the problem.
CruiserDreame...
PostPosted: 18:02 - 09 Mar 2011    Post subject: Reply with quote
I spoke to the DSA they told me it shouldn't have been done into the sun. They asked me to put in writing and then they will take a few weeks to think about it.
The test is intended to test the ability to swerve, not the ability to do it in extremes. If the intention is to test in extremes, it should be part of the test procedure, not on an ad hoc whatever happens on the day basis.
The test is supposed to establish a minimum standard. It is illogical to have a variable minimum standard.
Also, given the inevitability that cones would get run over sometimes, it seems an oversight to use cones that do not crush on impact.
Paulington
PostPosted: 18:22 - 09 Mar 2011    Post subject: Reply with quote
Good result there.
Have you rebooked your Mod 1 test yet?
CruiserDreame...
PostPosted: 18:40 - 09 Mar 2011    Post subject: Reply with quote
Not rebooked yet.
Since I made the first post my right arm has deteriorated. I can't lift it without the help of my left hand. So I will rebook in a week or so when its full function has hopefully returned. I can ride but I don't think I can safely push a bike at the moment.
I will post again when I get a reply from the DSA.
Thanks for the interest.
m0l0t0v
PostPosted: 21:20 - 11 Mar 2011    Post subject: Reply with quote
Shreddie wrote:
Paulington wrote:
Why?
Lol. No.
It's not hard to carry a visor around with you. It's not a hassle either. Strap it to yourself.
I'd rather have a visor strapped around me than wear glasses have an accident and for the glasses to break and pierce my face.
Paulington
PostPosted: 17:13 - 12 Mar 2011    Post subject: Reply with quote
Oddly enough when I had my accident with my glasses on, they didn't really 'pierce my face'.
They gave me a few lacerations for sure, but what they did do was shatter my zygomatic bone (upper cheekbone) and put a small fracture in my left orbit (eye socket).
Bear in mind they are Tag Heuer rimless though, so quite strong, these:
https://www.ioffer.com/img/item/917/008/81/o_obhcnfRxHYLNhxQ.jpg.
Now I make a point to wear contact lenses whenever I am on the bikes. Thumbs Up.
The last post was made 14 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 139.82 Kb
