Author |
Codemonkey |
 Codemonkey Crazy Courier
Back to top |
glassman50 |
 glassman50 Derestricted Danger
Back to top |
Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 17:03 - 20 Feb 2011 Post subject: |
If you've got it off chuck it in a bowl of oil for as long as you can, working the stiff links periodically. ____________________ My Flickr |
Back to top |
stinkwheel |
 Posted: 17:04 - 20 Feb 2011 Post subject: |
Soak it in hot grease or oil. Comes up lovely.
The old fashioned way was to bung it in a pot with a load of graphite grease, heat until the grease was just off boiling then allow to cool. Wipe off the excess and you're good to go.
Camping stove outside highly recommended. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
Codemonkey |
 Posted: 17:36 - 20 Feb 2011 Post subject: |
Cheers folks! Will try soaking in oil and also hot oil if I can find something to do it on (think Mrs Codemonkey would be none pleased if I do it in the kitchen ). |
Back to top |
iooi |
 iooi Super Spammer
Back to top |
devojunior |
 devojunior Brolly Dolly
Back to top |
Wafer_Thin_Ham |
Back to top |
Kickstart |
 Kickstart The Oracle
 Posted: 18:39 - 20 Feb 2011 Post subject: |
The O rings should seal it pretty well. If they are working then the paraffin probably won't get it. If they are wrecked then probably too late to save the chain. If I want to help a chain then I would just leave it soaking in a bottle of used engine oil (bit of string tied to one end to I can get it back out). But wouldn't expect it to work for an O ring chain.
I would try and manipulate the seized links to free them off.
Back to top |
rob_scott92 |
 rob_scott92 Could Be A Chat Bot
 Posted: 19:01 - 20 Feb 2011 Post subject: |
Back to top |
HD |
 HD World Chat Champion
 Posted: 19:35 - 20 Feb 2011 Post subject: |
Speaking of cleaning a chain im thinking of buying this for my bike:
https://www.thevisorshop.com/acatalog/Chain_Brush.jpg
So whats the best fluid for cleaning it with? Paraffin as you mention? Or just dip the brush in a bucket of soapy water? White spirit?
Sorry about the hijack codemonkey
 ____________________ Rusty '02 Vito Camper + CBR600F3 |
Back to top |
Codemonkey |
 Posted: 19:42 - 20 Feb 2011 Post subject: |
Back to top |
neil. |
 neil. World Chat Champion
 Posted: 19:44 - 20 Feb 2011 Post subject: |
I use one of those brushes with paraffin (sold as parasene in Homebase) and then after I've dried it off, brush some engine oil on the chain with an old paint brush and wipe off the excess. Yes it flings a bit but I've had over 15'000 miles out of my current chain/sprockets (riding 300 miles a week all year round in all the shitty weather we've had this winter) and only adjusted them 3 or 4 times since fitting, and by small amounts (up to notch 3 on the adjuster, not even half way there yet!). Get an automatic oiler like a Loobman as well to keep the chain wet.
Back to top |
Paxovasa |
 Paxovasa World Chat Champion
Back to top |
HD |
Back to top |
neil. |
Back to top |
Robby |
 Robby Dirty Old Man
Back to top |
ZebraDriver |
 ZebraDriver Scooby Slapper
 Posted: 21:11 - 20 Feb 2011 Post subject: BIN IT |
If its an o-ring chain and its gone stiff then the "O" rings are stuffed and they have allowed shit to get in between the pins, plates and the rollers. Even if you clean it, soak it, hammer it, lube it, boil it, brush it etc, etc the inside of the rollers will still be full of shit. This shit is rust, it will cause serious wear from the inside. If you run it afterwards the chances are all you will do is accelerate the wear and you run the risk of the chain snapping. The damage a snapped chain can do is considerable, not just to the associated gearbox output shaft and casings etc but to you as well if the back wheel locks.
As you have bought a new one then fit it and bin the old one.
By all means keep the sprockets as spares but if you want to run them buy another chain, for your bike its around £25
ZD |
Back to top |
Raffles |
 Raffles World Chat Champion
Back to top |
greetingsfrom... |
 greetingsfrom... Borekit Bruiser
Back to top |
Biggelo |
 Biggelo Derestricted Danger
Back to top |
Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Formerly known as Howling Terror
Back to top |
Codemonkey |
 Posted: 12:47 - 10 Mar 2011 Post subject: |
Well, in the end I opted for the safer route and fitted a new chain & sprocket kit together with a scottoiler. Was a bit of a learning experience being the most amount of bits i've had the bike in, but doing it myself instead of taking it to the dealer probably saved me the cost of the ABBA stand I bought at the NEC show last year
The old chain's still in the bucket of paraffin, probably ought to fish it out some time! |
Back to top |
The last post was made 14 years, 183 days ago. Instead of replying here, would creating a new thread be more useful? |
