Absolutely ridiculous!!
JodieWodie
Reflective Banana
PostPosted: 12:00 - 13 Aug 2004    Post subject: Absolutely ridiculous!! Reply with quote
I could, and suppose CAN do U-Turns.
I can.
Why then, with my instructor last night could I not do them !!! Twisted Evil
I put my foot down...too much throttle, too much clutch, not enough clutch, ridiculous!
I know we all have bad days and good but last night was just a joke. Neutral
I am going to the industrial estate tonight to practice.
The instructor told me to hold revs steady and work the clutch...sounds easy....MUST do this !!!!!! Shocked
(A woman I know failed her test last week as she put her foot down....she walked off ! Didn't want to carry on !! Shocked
Am a tad nervous now...)
That and my emergency stops...I tend to jam the rear brake on, instead of a lot of front and tap the back. I KNOW what I should be doing...it is just getting it fluent I guess.
Bum on bike time !! Thumbs Up
Courage doesn't always roar. Sometimes courage is the quiet voice at the end of the day saying, "I will try again tomorrow"
Rory
PostPosted: 13:27 - 13 Aug 2004    Post subject: Reply with quote
Yep, practice U turns, LOOK WHERE YOU WANT TO GO, keep the revs steady and slip the clutch and use your back brake just a little to control your speed.
Stopping - Apply front and back together and progressively squeeze harder. Don't savagely jam on the brakes. You can practice this in conjunction with U-turns if it's safe to do so - rapid stop from 30mph, U-turn, back down the road for another stop, repeat.
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
JodieWodie
Reflective Banana
PostPosted: 13:41 - 13 Aug 2004    Post subject: Reply with quote
Thanks Rory ! Thumbs Up
U-turns - I tend to look at the bike ..or straight ahead, which I KNOW is wrong !! Neutral
Look where you want to go ! is all my instructor says to me haha Laughing
The emergency braking is getting trickier..on my CBT, no problem, now it is harder !!
Go figure !!
McJamweasel
BCF Junkie
PostPosted: 14:16 - 13 Aug 2004    Post subject: Reply with quote
Once you can master looking up and where you want to go and not at the floor you'll find that it gets a lot easier.
As for the emergency stop - try practising with NO rear brake at all, then once you get that sorted re introduce the rear brake. Also, try and work up how fast you stop, begin fairly gently.
Jaz
PostPosted: 14:40 - 13 Aug 2004    Post subject: Reply with quote
As for failing your test on a U-Turn it depends on the severity of it.
All through my DAS I was told.. foot down = fail.
On my test I just lightly dabed the ground (due to dodgy throttle control at the time) and did the rest of the test thinking I had failed.
Almost dropped dead when he told me I'd passed though I did get 3 minors for that.
mrchips
PostPosted: 17:58 - 13 Aug 2004    Post subject: Reply with quote
For a U turn I was told the following by my instructor
Look behind
Into first
Look behind
Look behind
Slip the clutch
Just as you enter the turn apply rear brake and look over your shoulder
Spiral
PostPosted: 18:40 - 13 Aug 2004    Post subject: Reply with quote
When doing a u-turn sometimes i would put my feet out to give me a better balance and as long as they are not down on the ground it still counts.
When you get better with the balance you won't even need to put them out!
Also emergencey stop ? are you stopping to quickly jodie or locking a wheel or taking to long to stop?
****NORTHERN IRELAND NEWSFLASH!!**** According to a recent survey, 94% of loyalists said the best sex they ever had was in the shower; the other 6% haven't been to jail yet.***
ProXimaCore
Dougal
PostPosted: 21:11 - 13 Aug 2004    Post subject: Reply with quote
My instructor said you don't have to even bother with the rear brake on the emergency stop. The examiner can't see if you did it or not anyway. My NSR rear brake was awful so when I did it on their bike i was always hitting it too hard. So I just didn't bother.
As for U turns. Where you look is where you go. Always got told that one too. If you're on a bigger bike then you probably would be better not using the throttle for it at all. More than likely will need to give it some on a 125 though.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
divuk83
PostPosted: 07:53 - 14 Aug 2004    Post subject: Reply with quote
I was paranoid about U turns, all my practice ones were on really thin streets. When it came to my test the road I did it on was as wide as a runway Very Happy lucky or what!
Anyway, Just look at where you want to end up, do not look at the kerb. Gentle with the throttle, you wont fall off even if you go really slowly. The only thing that will make you fall is using your brakes or sudden use of the throttle. Good Luck.
Dave
izzi81
PostPosted: 13:35 - 14 Aug 2004    Post subject: Reply with quote
as others have already said, look where you want to go. I always found that the hardest part, and have discovered with my new bike I seem to have picked up the bad habit again of *not* looking where I'm going, but fixating on the road just ahead or - worse - the kerb I'm trying to avoid! I remember my instructor standing at the side of the road and constantly yelling at me to look at him and not at the kerb, I found it so difficult to do.
"The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81
Frost
PostPosted: 15:16 - 14 Aug 2004    Post subject: Reply with quote
My bike has stupidly good lock on it, so much so that you cant possibly get full lock on for more than half a second due to the difficulty of balancing with that much lock on, and the fact that the bars start to hit my knees.
On my test i was able to push the bike around with 4-5 inches to spare (front wheel was off the tarmac and onto the concrete bit by the side)
Fuck knows how, but i got it round with 2-3 inches to spare Cool
I think i put my foot down on my U turn, but i dont think it counted as all i had do was mirror check, set off, start slow riding, press rear brake to hard, come to a stop, foot down, mirror check, shoulder check, set off, slow ride,mirror check, look up the road, shoulder check, U-turn
So the foot down wasnt really on the U turn as i hadnt really started the manuver, i was still positioning myself suitabley.
TheShaggyDA
Repost Police
PostPosted: 01:41 - 15 Aug 2004    Post subject: Reply with quote
Also keep an eye on your chain adjustment - if it's drooping like a tart's knickers, you'll be pogoing as you keep taking up the slack.
JodieWodie
Reflective Banana
PostPosted: 01:54 - 15 Aug 2004    Post subject: Reply with quote
Thanks !!
thanks all xxxxx
Zen Dog
PostPosted: 03:21 - 15 Aug 2004    Post subject: Reply with quote
When I was practising my u-turns on the training school bike i ended up going so slowly the bike just fell over. The instructor told me to look where i wanted to go, but also to lean the bike over 45 degrees, while keeping myself bolt upright.
That way, the bike turns much better, and the rider gets to keep their pride intact. Smile
PS. Using the rear brake and not the front, and using variable clutch with constant throttle helps as well.
Shade_BW
I'm better than you
PostPosted: 20:26 - 15 Aug 2004    Post subject: Reply with quote
they are a bugger
day before my test i screwed them up completely, so went out that night to practice on the girlfriends bike.
You have bad days, but you will get better. Lots of practice helps.
I found i was worrying a lot about the kerb, big mental block, so practice where there isn't a kerb. In a car-park for example.
Once you know you can do it, then go back and try it on the road.
And once you've passed your test, you won't have to worry about them ever again, because you can choose not to do them Very Happy
Shade
Don't remember if I do them or not now.
If you like this post, rate it!
Karma is there for a reason.
Frost
PostPosted: 23:03 - 15 Aug 2004    Post subject: Reply with quote
no one ever does a proper U turn after their test, they turn in someones drive, or do a wide U turn.
Annabella
Like a person, only smaller
PostPosted: 13:50 - 17 Aug 2004    Post subject: Reply with quote
I definately found, relaxing and not concentrating helped with my U turns. That being said, I failed on my U turn first test attempt - I put my foot down Embarassed
As for emergency stops, I always used my back brake far too much. To get over this I practised stopping with just the front brake by placing my toes on the peg rather than nervously over the brake lever Thumbs Up
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Munday
PostPosted: 18:17 - 17 Aug 2004    Post subject: Reply with quote
I failed my first test because I put my foot down on a U-turn - silly me Sad
Bikes: Honda CBR250R | Honda ST70
ShortR6
PostPosted: 01:06 - 18 Aug 2004    Post subject: Reply with quote
The most useful bit of information for me from my instructor was, As you start the turn pull the clutch in, kill the throtle and lean the bike in to the turn and as you feel the bike tip over bring the revs back up and in-gage the clutch. When done correctly 2/3 of the turn is completed in the first half of the road giving you ample room and time to find you finishing spot.
This really helped for me but everyone is different and requires different instruction.
Andy
Short but not sweet.
Trunecka
PostPosted: 01:23 - 18 Aug 2004    Post subject: Reply with quote
Bet your instructor had ridden offroad before. My instructor noticed I rode offroad on my first practice U-turn!
"I'm gonna get free, Ride into the sun..."
-The Vines
dibbster
PostPosted: 01:44 - 18 Aug 2004    Post subject: Reply with quote
My instructor had me doing figure of eights round two tight cones to help improve my slow speed bike control which helped improve my u-turns. Could turn the CG on a sixpence not at that level with the RF, but to be honest once you have done your test you don't bother u-turning 'properly' all the time.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
The last post was made 22 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 114.63 Kb
