RD125 YPVS controller in TZR 125
Snorty
PostPosted: 12:22 - 11 Mar 2011    Post subject: RD125 YPVS controller in TZR 125 Reply with quote
I've spotted a power valve controller for an RD125, I already have a servo for the bike, I just need the controller.
Would this work in a TZR? The connections look a bit different but I imagine they could be butchered to connect to the loom, and they're both similar bikes, single cylinder.
I don't want to fork the money out and it not work... I'm really desperate to get the best of both worlds out of my bike, it pulls really nicely from 4k but just dies around 8k until you shift up.
Any help/advice appreciated on this one, cheers.
PostPosted: 12:25 - 11 Mar 2011    Post subject: Reply with quote
Why not try to fix the problem with the bike you have, rather than trying to bodge on a controller from a totally different bike with a totally different engine? I'd imagine that a powervalve controller from a DT125 of similar era to your TZR would be better than the RD one.
What is exactly wrong with your bike? Do you know?
Snorty
PostPosted: 12:36 - 11 Mar 2011    Post subject: Reply with quote
There's nothing wrong with my bike anymore. Just needed a top end rebuild and a carb rebuild. Runs sweet as now.
Can't find a controller for my bike anywhere, they pop up rarely on eBay but there are none at the moment, so I'm trying to find alternatives.
PostPosted: 12:39 - 11 Mar 2011    Post subject: Reply with quote
So there is nothing wrong with it, and yet it needs a controller? Are you saying it doesn't have a controller at all?
I'd suggest going to a motorcycle parts place and ordering one, as Yamaha tend to have reasonably priced parts for bikes up to 20 years old. I don't think it would cost you too much to get a new one, and at least you would know it was correct.
PostPosted: 12:41 - 11 Mar 2011    Post subject: Reply with quote
Only the very late RD125s had the power valve, and don't think any UK ones had the control units or servos (and the setup with pretty much the same as the TZR I thought). They were only sold in tiny numbers in the UK. As such I would expect an RD control unit to be far rarer in the UK than a TZR one, and would be suspicious that the one you are looking at is from something else.
PostPosted: 12:43 - 11 Mar 2011    Post subject: Reply with quote
TZR125 in the UK didn't have the servo or controller. They were sold as optional extras if you could prove you had a full license but were uncommon 20 years ago when they were current bikes, let alone now.
Not sure they are still available from Yamaha and the price if available would probably be 25% of the value of the bike.
Snorty
PostPosted: 13:52 - 11 Mar 2011    Post subject: Reply with quote
This is true... £225 + VAT Shocked
I guess I'll just have to save up for my full test.
cloric_tzr
PostPosted: 14:32 - 11 Mar 2011    Post subject: Reply with quote
there seems to be a lot of tzr talk. keith is right the pree 1994 tzr's i.e 1987-1989 2rk's 1989-1990 3pc1 1990-1991 3pc2
and 1991-1994 3pc3 all have the ypvs system pegged into place.
they have the plugs avaliable to connect the servo, but a far cheaper option is to do what ive done and open the valve fully takes 20mins.
you get full top end power just like if you have the valve, but you sufer from a splutter at 4.5-5000rpm when not on the valve due to lack of back pressure and torque but once on the valve no problems as the revs dont drop below 7000rpm and scream right up to 11000 most noticable power increase is between 9000-10500 rpm where she really screams.
myself as a precation adjusted the oil pump to allow more oil through which seems to have been the right choice no extra smoke and no overheating ive done 6000 miles with the valve open and she was still going strong.
the only other increase other than power is fuel consumption
i get 80-90 miles to a full tank of fuel and 200-300 miles to a tank of 2 stroke oil (depending on how i ride)
if you do want to buy the servo from what ive seen its 70+ quid fora servo and 40+ for the pulley system.
rick
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
PostPosted: 14:46 - 11 Mar 2011    Post subject: Reply with quote
Reason you get it isn't a lack of back pressure. A performance exhaust works by bouncing pressure waves around and they are timed to bounce back to the exhaust port and back away again as the port opens sucking the next lot of exhaust gas out (and mixture in). But the pressure waves move at a pretty constant speed irrespective of revs, so at the engine speeds it isn't optimised for the pressure wave arrives at the wrong moment and rams the exhaust gases back into the engine instead.
The power valve acts as, effectively, variable valve timing on the exhaust and helps to prevent the port timing and exhaust design set up to give you top end from destroying too much of the bottom end power.
But I agree, almost everyone just opens the valve manually.
Truzo
PostPosted: 19:04 - 11 Mar 2011    Post subject: Reply with quote
I have the same problem with my rd.
I have the servo motor and pulley but no control box!
I have also been told i will need to change my cdi.
There is two kinds of servo. one with the control unit built in and one that isnt, I think it would be hard to mix n match from different bikes.
Your best bet would be to buy new or TRY and find someone thats braking a tzr that has a fully working ypvs system.
Current Bikes: RXS 100, RD 125lc3, RD 350 F2
The last post was made 14 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 72.04 Kb
