coolant change
dudejb46
PostPosted: 09:17 - 12 Mar 2011    Post subject: coolant change Reply with quote
I may be dumb but, I know I need coolant in my 400, (its pure water atm!) But how much? Is it pure coolant or a water mix?
Thank you
2002 zip 2002 bandit project 2004 fzs1000 2009 883r
salty21
PostPosted: 09:43 - 12 Mar 2011    Post subject: Reply with quote
its usually a 50/50 mix of coolant and distilled water Thumbs Up
dudejb46
PostPosted: 09:46 - 12 Mar 2011    Post subject: Reply with quote
Thank you
gray84
PostPosted: 09:49 - 12 Mar 2011    Post subject: Reply with quote
yep normally 50/50 and try and used distilled water. try and flush distilled water through to remove the normal hard water if you can really be arsed...
Robby
Dirty Old Man
PostPosted: 10:45 - 12 Mar 2011    Post subject: Reply with quote
If it's been running on just water for a while then it could be worth doing a flush using a rad flushing liquid first. Coolant contains corrosion inhibitors, water does not. Corrosion means that very small bits of shit will build up in small passages and restrict the colling efficiency, which is bad.
Personally I would drain it (following the manual, could be multiple drain points), flush the engine and the rad with a hosepipe, then fill with normal tap water and flushing chemical to flush it by the instructions on the bottle. If it says 15 mins on tickover, then do that, not 3 days on the redline. Drain and flush with a hose a couple more times, then refill with coolant by the instructions in the manual. If may advise you to run it up to temperature with the expansion cap removed first.
I never use distilled water, I change coolant yearly and it has corrosion inhibititors so tap water isn't going to kill it. If you're planning on going down that route, you may as well just get ready mixed coolant, only tend to need a couple of litres for a bike.
A useful future tip - choose a type of coolant and stick to it. It's difficult to completely remove all of the old coolant, so changing to a different colour can make it look dirty. I found this on my car, which had very old green stuff in when I got it and I changed to blue. 2 changes later and there's still a slight green tinge in it.
Shreddie
PostPosted: 15:33 - 12 Mar 2011    Post subject: Reply with quote
Some coolant is premixed though so there's no need to dilute it. If in doubt, read the back of the can.
salty21
PostPosted: 18:02 - 12 Mar 2011    Post subject: Reply with quote
tesco do 1L of premixed coolant for £3 a bottle
PostPosted: 19:15 - 12 Mar 2011    Post subject: Reply with quote
Pretty sure Wilkinson's is cheaper than that. I'd even see what the pound shop had on offer. All coolants are the same at the end of the day, just check what temp it will go down to.
magpiemale
PostPosted: 19:39 - 13 Mar 2011    Post subject: Reply with quote
yeah wilkinsons have it comma I think !! premixed and only a pound or so
NSR125 1992 (sold) kawasaki Z750S,fazer FZ1 07 now gone present bike 2012 fz1s Fazer,beowulf rad protector,heated grips,sw motech gps holder,power socket.
The last post was made 14 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 61.21 Kb
