OIL SPEC
Dan JP
PostPosted: 17:05 - 12 Mar 2011    Post subject: OIL SPEC Reply with quote
My bike manufacturer (megelli) recommended i get 15/40w oil, but after abit of reading up on the web, i have found out that the 10/40w has replaced the old 15/40w as it offers better cold start flow properties that an 15w-40 oil but the same viscosity when at operating temperature.
Should i stick to looking for a good 15/40w oil, or should i get the 10/40w ?
Dan
Whatever doesn't kill you, Only makes you stronger
Shreddie
PostPosted: 17:44 - 12 Mar 2011    Post subject: Re: OIL SPEC Reply with quote
Ignore this post, it's bollocks!
But I'm leaving it here so the thread makes sense.
You've got your viscosities the wrong way round... The '10' or '15' is the viscosity when at normal operating temperature. The 'w40' is the cold start viscosity ('w' stands for winter). In other words, as they both end with 'w40', their cold start properties will be the same. At operating temperature however, the 10w40 will be thinner/less viscous. The lower the number, the less viscous the oil. As an example, gear oils can be SAE80 or 90 and are almost like syrup, very thick indeed.
Well, 15w40 does seem an odd number for them to ask for as I've never heard of that particular grade for bikes. 15w50 yes, but not 15w40. The problem with a 10w40 is that the thinner viscosity at operating temperature may not offer enough protection for your engine as less viscous oils protect less well... With that in mind, I'd be more inclined to buy a 15w50 oil instead.[/b]
weasley
PostPosted: 18:47 - 12 Mar 2011    Post subject: Re: OIL SPEC Reply with quote
Shreddie wrote:
Mostly fiction
You're wrong, the OP was right. The first number is the winter grade, the second is the summer grade. The lower the first number, the colder it can operate at. SAE viscosities are written eg 15W-40. Also, gear oils are measured on a different scale to engine oils, so you can't compare 80W-90 to 15W-40; some gear oils are thinner than engine oils.
To the OP, 15W-40 hasn't really replaced 10W-40, both are available and do different jobs. Your assertion about temperature is right and 10W-40 would offer a little cold weather benefit. Also 10W-40 would tend to be a higher quality oil (not always, but typically).
Shreddie
PostPosted: 20:25 - 12 Mar 2011    Post subject: Re: OIL SPEC Reply with quote
weasley wrote:
Shreddie wrote:
Mostly fiction
After a little research, I stand corrected!
I clearly remember reading that pile of tripe somewhere years ago though. Hmmm.
The last post was made 14 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 41.37 Kb
