Yes or No answer - MD80 Memory Card Help!
HD
PostPosted: 22:12 - 13 Mar 2011    Post subject: Yes or No answer - MD80 Memory Card Help! Reply with quote
So I have bought one of those cheapy ebay jobbies like plenty of you but I have an issue with buying a memory card...
Basically the 8gb Class 6 ones seem to be SDHC. Now are the 'HC' ones compatible or is it for something else? I can only really seem to find SDHC for 8gb Class 6 memory cards so help would be greatly appreciated.
I have found a samsung one for £13 on play.com but this is also a HC one...
Or can anyone recommend one?
Thankyou!
Flip
PostPosted: 22:20 - 13 Mar 2011    Post subject: Reply with quote
https://www.google.co.uk/#sclient=psy&hl=en&q=can+i+use+sdhc+instead+of+sd&aq=1c&aqi=g1g-c1&aql=&oq=&pbx=1&fp=fbaa67012a7424e2
HD
PostPosted: 22:24 - 13 Mar 2011    Post subject: Reply with quote
I'm not sure if the camera is compatible with a SDHC, I was wondering if anyone had any experience as I dont wanna buy one and then it doesnt work...
jay12329
Dr. Evil
PostPosted: 22:29 - 13 Mar 2011    Post subject: Reply with quote
Buy one, if it doesn't work send it back. Or for 13quid keep hold of it until you buy something else that requires sd cards.
J
HD
PostPosted: 22:32 - 13 Mar 2011    Post subject: Reply with quote
J
Problem is, it is for the father...
jay12329
Dr. Evil
PostPosted: 22:35 - 13 Mar 2011    Post subject: Reply with quote
Why is that any more of an issue than if its for you? Just buy try and get on with your life. I've earnt more than 13quid in the time taken to write, read and respond to this topic!
coolhands
PostPosted: 22:39 - 13 Mar 2011    Post subject: Reply with quote
I think you need microsd. normal sd or sdhc is too large. Buy this one (sandisk is great make and very reliable. it is much cheaper than whatever you're looking at on play.com):
https://cgi.ebay.co.uk/8GB-SAN-DISK-MICRO-SD-MICROSD-SDHC-MEMORY-CARD-NEW-UK-/270679640019?pt=UK_AudioTVElectronics_PDAsAccessories_MemoryCards&hash=item3f05c387d3
iooi
PostPosted: 22:47 - 13 Mar 2011    Post subject: Reply with quote
8 gig class 4 just over 8 quid.Works a treat in mine.
HD
PostPosted: 22:57 - 13 Mar 2011    Post subject: Reply with quote
Both of those are SDHC :/
iooi, is that the exact one you bought?
And what sort of problems would I encounter if it is the wrong card?
Ichy
PostPosted: 23:09 - 13 Mar 2011    Post subject: Reply with quote
Nice and simple, just buy a micro SD card, class 4 minimum. They all do the same, HC means High Capacity.
Some older stuff won't work with HC but I tried 4 or five cards with these cameras and they have all worked just fine.
HD
PostPosted: 23:14 - 13 Mar 2011    Post subject: Reply with quote
Four or five SDHC cards? Sorry Laughing Just want to make sure...
Ichy
PostPosted: 23:18 - 13 Mar 2011    Post subject: Reply with quote
Dude you worry too much! Yes MicroSDHC.
These are the EXACT ones I used last year.
https://www.play.com/Mobiles/Mobile/4-/12761320/Samsung-4GB-Micro-SDHC-Memory-Card-Class-4/Product.html?searchtype=allproducts&searchsource=0&searchstring=microsd&urlrefer=search
Jim Mc
PostPosted: 23:38 - 13 Mar 2011    Post subject: Reply with quote
You'll have to buy a 2GB or smaller SD card for it to be non SDHC, all cards over 2GB are SDHC.
So if it supports greater than 2GB, it presumably must support SDHC.
HD
PostPosted: 00:10 - 14 Mar 2011    Post subject: Reply with quote
Marki wrote:
You'd best be right Wink Karma
69.9mph
PostPosted: 00:36 - 14 Mar 2011    Post subject: Reply with quote
I asked Veho which class card I should use and got the reply:
Hi 69.9
We recommend a class 6 card.
Many thanks,
Veho Tech Team
Visit our new online store, Lifestyle Shop, at https://www.veho-lifestyleshop.com/lifestyleshop/index.aspx and use VEHO20 at the checkout to receive a 20% discount off your order!
That was from technical@veho-uk.com
Shreddie
PostPosted: 00:50 - 14 Mar 2011    Post subject: Reply with quote
SD is anything up to and including 2gig, SDHC (High capacity) is 4gig and higher. SDHC cards are not compatible with everything so read the manual on the device you want to use them with, it will tell you if it's SDHC compatible and if so, the maximum capacity of the card it will take. As an example, both my camera and my field recorder take SDHC cards but the camera can only take up to 8 gig while the field recorder can handle up to 64gig. However, the field recorder could only take up to 2 gig SD cards before I applied an OS update.
One of the problems with some of the cheaper cards and USB sticks (usually those from China) is that they are labeled 8gig or whatever and appear as 8 gig to your computer but will get corrupted as soon as you try to put more than 512 mb data or whatever on them... In other words, they're only 512mb cards that have been reprogrammed and relabeled. Other cheaper cards which do have the capacity aren't always reliable and can fail. Make sure you do your research on the seller and on the cards.
iooi
PostPosted: 10:36 - 14 Mar 2011    Post subject: Reply with quote
Yep I got that one.
No probelms.
Even works with the old key fob cam.
As other have said check that it will take the size (gig) of the card and you will be fine.
If you have only just got it then 8 gig should be fine.
DrDonnyBrago
PostPosted: 15:30 - 14 Mar 2011    Post subject: Reply with quote
I use a micro 4gb SDHC in mine, had no issues.
iooi
PostPosted: 21:28 - 14 Mar 2011    Post subject: Reply with quote
today
8 gig class 2 in the key cam (off side cam)
8 gig class 4 in MD80 (nearside cam)
Just awaiting HD key cam to see just how good they are. Thumbs Up
The last post was made 15 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 101.51 Kb
