| Adam.I |
 Adam.I World Chat Champion
| N cee thirty |
 N cee thirty Banned
 Posted: 23:08 - 15 Mar 2011 Post subject: |
hmm
just try all the basics first really
oil
carb
air filter
valves
plug
then check over the electrics for any breaks in the wiring  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| fiery tupp |
 fiery tupp Trackday Trickster
| Adam.I |
| fiery tupp |
| Adam.I |
| fiery tupp |
 Posted: 00:24 - 16 Mar 2011 Post subject: |
They are very easy to work on & although the 94 model will have a manual cam chain tensioner that, I dont think will be in your manual .
though the carb is very simple , if you need to stip it , with no heater or diaphram etc , like the newer ones .
& I dont think I would be brave enough to try doing 125 miles on a strange old one  ____________________ If you can't fix it with a hammer , use your head . |
| Adam.I |
| N cee thirty |
 N cee thirty Banned
| Adam.I |
| weasley |
 weasley World Chat Champion
| Adam.I |
| Adam.I |
| N cee thirty |
 N cee thirty Banned
 Posted: 14:15 - 19 Mar 2011 Post subject: |
hmm the starter motor could be fubar
before bump starting it,put some petrol down the plug hole  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| Adam.I |
| N cee thirty |
 N cee thirty Banned
| Adam.I |
| Adam.I |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 18:31 - 19 Mar 2011 Post subject: |
apparently they're pretty renowned for rocker problems. see if it's snapped.
I even helped out some kid who'd broken down on an SR125, same problems as you, on inspection after i'd got home, got some tools and come back, it'd dropped an exhaust valve.
good luck.
oh yeah, then someone pulled over at the side of the road, stole his gloves and helmet then fucked off.
lolz ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Adam.I |
| N cee thirty |
 N cee thirty Banned
 Posted: 21:36 - 19 Mar 2011 Post subject: |
just take all the jets out and blow through them untill you can see light
imma guessin the rockers come loose  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
| fiery tupp |
 Posted: 00:38 - 20 Mar 2011 Post subject: |
Yes, i'm afraid they are prone to top end failures , when oil changing the check bolt shown ,(*though that woud happen within a very short time after oil change *)
is often missed which dosen't help along with regular oil & filter changing & if the oil's not getting to the cam ..crunch .
I would take the valve inspection covers off & the flywheel cap & turn with a socket anti clockwise , you should be able to tell any damage .
Another thing that I found on this a friends bike , was the fuel pipe routed like shown , slowing flow & cutting out every few miles , had him baffled , simple but easily missed . probably wont help you but worth noting , for anyone with that problem ?
* It sounds like the owner didn't do the oil etc regular it could have sludged up & balls the oil pump up , then just could't cope with a 50 mile run* ?
*Edit* ____________________ If you can't fix it with a hammer , use your head .
| kat250 |
 kat250 World Chat Champion
There is a gap of 5 years, 172 days between these two posts... |
| Robg123 |
 Robg123 Derestricted Danger
| Suntan Sid |
 Posted: 23:24 - 06 Sep 2016 Post subject: |
5 years later, probably rusted away by now! ____________________ "Everybody needs money, that's why they call it money!"  |
The last post was made 9 years, 206 days ago. Instead of replying here, would creating a new thread be more useful? |
