Lost my bike key, what the hell do I do!?
BlackStallion
PostPosted: 19:25 - 16 Mar 2011    Post subject: Lost my bike key, what the hell do I do!? Reply with quote
It's my only key, tried getting it cut many times, but no where does it, none of them accept my key for some reason. Rolling Eyes
Anyway, I've had to leave my bike at college, hope it doesn't get nicked Sad the steering lock is on, and obviously without that key I can't start it, what do I honestly do? Rolling Eyes
Been about 2 years, and I've never lost it, until now. I've re-traced my footsteps around town, asked in stores I've been in, all my tutors at college... no luck, its basically gone, just need to know what the fuck I do now?
I'd highly appreciate any help, I need the bike for college on Friday and work this weekend!
Thanks in advance Thumbs Up
Moo.
PostPosted: 19:41 - 16 Mar 2011    Post subject: Reply with quote
How easy is it to change the ignition barrel? I was thinking about this earlier for my bike, its just a case of taking clocks off, unscrew face, unscrew barrel, unplug and install a new one Shocked makes stealing it look easy...
A2 Passed 18/6/10
fiery tupp
PostPosted: 19:49 - 16 Mar 2011    Post subject: Reply with quote
I'd get a van to it asap , then sort the key when its safely home Neutral
If you can't fix it with a hammer , use your head .
PostPosted: 19:51 - 16 Mar 2011    Post subject: Reply with quote
Well... a thief doesnt need a key, neither should you Razz
If its the XRX, barrel just smashes out Wink unsure how to solve the steering lock bar breaking it.
Some people can get a key from using your barrel as a mould...hard to find though.
Ignition locks are normally held on with sheer bolts. The heads sheer off when tightened up just leaving a round part of the head that convention spanners / sockets will not remove.
To the OP. Getting the lock off will be difficult, same for the petrol cap and seat lock. You might be able to find a local mobile locksmith who can cut a key to the lock, but don't expect it to be cheap.
Replacing the locks will be more expensive (£200 wouldn't surprise me for a lock set) and will mean removing the existing locks.
If you are very lucky then you might be able to find a number on the ignition barrel and find someone who can cut a key to that number (note that the petrol tank and seat locks usually have less tumblers, and an ignition key will turn them but a key cut just for them will not turn on the ignition).
Ingah
PostPosted: 20:48 - 16 Mar 2011    Post subject: Reply with quote
When i had my CB500 ignition switch replaced, it was only ~£30 for a pattern one.
-- Ingah
PostPosted: 21:18 - 16 Mar 2011    Post subject: Reply with quote
He is going to need the full set though, not just the ignition. Probably an ignition switch pattern, maybe a fuel cap but probably not a seat lock.
And the cheap pattern switches I have had have been pretty horrible.
froggy128
PostPosted: 21:37 - 16 Mar 2011    Post subject: Reply with quote
Had this happen in the city center ended up just hammering the ignition until it would turn and start so I could get the bike home and then sort out a new ignition barrel.
If the number is on the barrel you should be able to get a key cut to it.
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
truslack
PostPosted: 23:42 - 16 Mar 2011    Post subject: Reply with quote
lonie wrote:
does the bike ahave a kickstart?
if so unplug the barrel and kick it over and it should start you will not have any electrics though :/ so do it in daylight and if you get stoped then expain to the officer (nake sure you taake the cdocuments with you
That will only work on bikes where the ignition switch just grounds the coil to earth in the off position (and connects lighting circuits etc to + in the on position)
Redoko
PostPosted: 23:56 - 16 Mar 2011    Post subject: Reply with quote
V5 is NOT proof of ownership.
Moo.
PostPosted: 00:23 - 17 Mar 2011    Post subject: Reply with quote
A little off topic.. how do you actually prove you own a vehicle?
Not sure if this would work.. could you claim you've broken down, and get recovery to take you home? (maybe explain the situation to the bloke?)
A2 Passed 18/6/10
Redoko
PostPosted: 00:46 - 17 Mar 2011    Post subject: Reply with quote
Unofficially I suppose you could explain your situation.
But busting open a ignition barrel looks dodgey to anyone.
CaNsA
PostPosted: 01:05 - 17 Mar 2011    Post subject: Reply with quote
Have you checked that you havent left it in the ignition/seat lock?
Charlie
PostPosted: 01:15 - 17 Mar 2011    Post subject: Reply with quote
By providing a receipt of purchase. Thumbs Up
johnsmith222
PostPosted: 04:57 - 17 Mar 2011    Post subject: Reply with quote
you prove you own the vehicle by letting the police do their check and showing them your licence or other ID.
I have successfully stolen my bike 3 times because of high amounts of fail, whether that be crashing and then forgetting where I put the keys after the crash (with the alarm going off every 30 seconds), or riding away with a disc lock on, buggering it and spending an hour cutting it off with a junior hack saw with over a hundred people walking past.
BlackStallion
PostPosted: 09:54 - 17 Mar 2011    Post subject: Reply with quote
Cheers for all the replies guys, luckily my breakdown covers the loss of a key, so I can get it to a specific destination, I'm thinking of a locksmith like some of you mentioned. I don't have a seat lock by the way, and Kickstart, I really hope it doesn't cost that Rolling Eyes
I rang a fairly local Hyosung dealer and got their advice, and they recommended a mobile locksmith, the one in Chatteris, which isn't far from here. Anyway, gave them a ring and they don't do motorbikes? Rolling Eyes I need to look around.. Find somewhere that would do it.
Oh and lonies mate, the earlier models of the XRX did have a kickstart, but mine's just electric start unfortunately, always liked the options of having 2 methods of ignition.
Kickstart, will I really have to replace my whole ignition barrel? I just need somewhere that would cut a key for me, but if key cutters won't even cut the key when I had it, it makes me think, are they really gonna be able to do this? Rolling Eyes
Froggy girl, I'll check for a number when I go back to my bike, the Hyosung dealer mentioned that, he said without it I wouldn't be able to get a key cut for it?
Cheers for the help, appreciate it big time Karma
ride_to_die
PostPosted: 10:42 - 17 Mar 2011    Post subject: Reply with quote
Happened to me many moons ago. I called out a locksmith who made me a new key using the petrol tank lock. He did it in the back of his van. Cost me £80.
I'm not here for a long time, I'm here for a good time.
truslack
PostPosted: 10:52 - 17 Mar 2011    Post subject: Reply with quote
A PNC check shows the registered keeper, not the owner - the same as the V5.
PostPosted: 11:03 - 17 Mar 2011    Post subject: Reply with quote
Mobile lock smith is likely to charge between £50 and £100, if they can get a key blank (last one I used charged me £65 I think, but that was with me taking the lock to them).
Find the price of a lock set. A quick browse round and I can't find it online although US price for one for a GT250 suggests Hyosung prices are not that high.
Unless someone can cut a key to fit the barrel (either by careful checking or from the number) then almost certainly you will need to replace the whole barrel, and a new barrel means the new key won't fit any other matching locks on the bike.
stirlinggaz
PostPosted: 17:49 - 17 Mar 2011    Post subject: Reply with quote
i've got keys cut for a few bikes (lost key,bought without keys etc)
& the easiest/cheapest way is to remove the barrel.
as Kickstart says, there is usually at least one security rivet, which can be removed by cutting a slot in it, & then loosening it with a screwdriver or imact driver.
once you have the ignition barrel off, by-pass the ignition switch & ride it home.
done this a few times & fitted a hidden a on/off switch, so i could use the bike whilst waiting on the new key.
(couldnt find a local locksmith & bike shop takes a couple of days)
then just take the barrel to any bike shop or decent locksmith.
locksmith will cut you 2 new keys for around 40 quid (max).
bike shop will be a bit more as he will send the barrel to locksmith & needs to make a profit.
then just refit, using normal button headed bolts,
if you do use a mobile locksmith, expect to pay around double, these guys make there money out of the call out charge,
cheers,
GAZ
Flip
PostPosted: 15:51 - 18 Mar 2011    Post subject: Reply with quote
Hammer and a screwdriver will open it to access the allen bolts to get the petrol cap off.
A maybe...
Reach under the rear fairing and you may be able to get to the cable. Pull it and your seat should come off. Failing that, try the hammer & screwdriver again.
Works on old bikes anyway.
It could be worth having your V5, insurance docs and proof of ID if you're not doing it at home.
Ditto
PostPosted: 16:17 - 18 Mar 2011    Post subject: Reply with quote
Ive suffered the same problem as Milkster.
Where can you get a bike key cut? Everyone I go to just says
"Nah sorry mate don't do bike keys"
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
Flip
PostPosted: 17:21 - 18 Mar 2011    Post subject: Reply with quote
https://www.timpson.co.uk/ Had one cut for my Yamaha and my ZXR400 when I had it.
PostPosted: 17:39 - 18 Mar 2011    Post subject: Reply with quote
Buy the key on eBay and take the blank and the original.
Also everybody else is lock smiths seem to be shit, I have never had trouble worse than having to order the key in. When my Triumph needed a key the guy took the original and went through a book then matched it on the book.
I had more trouble getting my Givi Key cut. In the end it was cheaper to buy a new barrel and keys than get one key cut.
The last post was made 15 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 134.67 Kb
