Help, my rim is leaking!!
L-Jam
PostPosted: 00:58 - 20 Mar 2011    Post subject: Help, my rim is leaking!! Reply with quote
Mr. Green
Basically lads and ladettes, I have had a new tyre (bt023) fitted a few weeks ago on the CBR, and the tyre seems to lose psi quite quickly. The old tyre did it, so I blamed it on a puncture that had been repaired, but since the new tyre has been fitted it has gone from 42psi to 9psi in 3 weeks. WTF?
Does this mean the rim is damaged? Also the tyre bloke said that my wheel didn't have much weights on it at all, does this affect anything?
Cheers guys, I'm selling the bike in a month anyway so am not massively bothered as I will just do the pressure every week to keep it up 'till then, but would like to be able to resolve this if possible.
Journalist, student, egotist.
c_dug
PostPosted: 01:06 - 20 Mar 2011    Post subject: Reply with quote
It does sound like a damaged wheel, my ZZR was loosing pressure at a pretty similar rate and the flat spot was really clearly visible so give the wheel a good checking over and see if you can spot anything obvious.
fiveus
PostPosted: 02:15 - 20 Mar 2011    Post subject: Reply with quote
Had this problem before
remove tire and sand down any loose paint on the rim
you will then get a decent seal Thumbs Up
PostPosted: 02:44 - 20 Mar 2011    Post subject: Reply with quote
First check the valve isn't leaking. A blob of spit in the end of the valve and watching for bubbles is the traditional way.
Then swill a load of soapy water round the rim. You should see a leak.
You can sometimes get tyre beads to seat properly by taking the valve core out and quickly inflating it to 80-90psi. Another trick is to run a line of neat washing up liquid round the edge of the beads then do the inflating thing. Remember to wash it off again after.
Be aware that tyres can blowout at this pressure, but rarely. It's what they do when they fit them.
Towton 1461
PostPosted: 02:55 - 20 Mar 2011    Post subject: Reply with quote
Alternatively, take it back to garage where the tyre was fitted and tell
them your problem. They'll no doubt have an old water-filled tank to
look for escaping air.
If the wheel runs true without much added balance weight being needed,
that's fine.
This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief!
L-Jam
PostPosted: 03:48 - 20 Mar 2011    Post subject: Reply with quote
It was a mobile tyre fitter who sorted me out, really sound guy too. I should have mentioned it tbh.
Cheers for the ideas, I'll give it a crack tomorrow when I get up my Dads after work.
PostPosted: 09:41 - 20 Mar 2011    Post subject: Reply with quote
When I read the title I was expecting THAT picutre! Shocked
Slacker24seve...
PostPosted: 09:51 - 20 Mar 2011    Post subject: Reply with quote
Well done pinky. NSFW tags required in 5...
Banger rallies are ace
PostPosted: 09:59 - 20 Mar 2011    Post subject: Reply with quote
https://i50.photobucket.com/albums/f333/earthtwinkle/Smilies/smiley_signinsertevillaughhere.gif
Dazbo666
PostPosted: 10:54 - 20 Mar 2011    Post subject: Reply with quote
Yup, me too Sick
Word of the day : DILLIGAF
The last post was made 15 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 68.81 Kb
