| Jayy |
 Jayy Mr. Ponzi
| bacon |
 bacon World Chat Champion
| stevekingchef |
 stevekingchef Crazy Courier
| Jayy |
 Jayy Mr. Ponzi
| Jayy |
 Jayy Mr. Ponzi
 Posted: 20:14 - 21 Mar 2011 Post subject: |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:17 - 21 Mar 2011 Post subject: |
notched clutch basket, hence the URRKK, and worn clutch plates from fail wheelies. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Jayy |
 Jayy Mr. Ponzi
| woll |
 woll World Chat Champion
 Posted: 20:59 - 21 Mar 2011 Post subject: |
New clutch plates, possibly a new clutch basket ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| Jayy |
 Jayy Mr. Ponzi
| CRF_Rider |
 CRF_Rider Spanner Monkey
 Posted: 22:35 - 21 Mar 2011 Post subject: |
sounds like it may also be bogging down a little too on the throttle. if your in rochdale then i think the nearest is Eurotek KTM in ripon. good place, decent service, although rather expensive. ____________________ Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp |
| Tristan. |
 Tristan. World Chat Champion
| MaybeGuy |
 Posted: 22:48 - 21 Mar 2011 Post subject: |
you can just file a clutch basket smooth again. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Tristan. |
| Jayy |
 Jayy Mr. Ponzi
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 23:24 - 21 Mar 2011 Post subject: |
There is some good points there I would look through first.
You might find that a decent service ie@
Oil filter, plugs, air filter, oil, carb clean + balance. Give it a new set of brake pads and clean the calipers all round. Also clean all the electrical connections to and from coil and battery.
The see if the noise still persists. If so, take it apart and have a look at the basket and plates, then replace parts as required!
Best way of doing it tbh. I'd start with a decent service though. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Jayy |
 Jayy Mr. Ponzi
| 0l0dom0l0 |
 Posted: 23:34 - 21 Mar 2011 Post subject: |
| Recoil Jay wrote: | You think I should just take it somewhere else and have them do all the work? I think brake pads/oil/filter change can be done by me/TUG and then take it somewhere to check the power loss problems. |
Everything I listed above you should be fine doing. if you do that first (before giving it to the dealer), then it might solve the power loss problem (my money says it does) and then you don't have to pay a dealer to look at it.
You have got to just way up how long/ how much they are going to charge to look/fix it, because you might be better off selling as is. dealers are so expensive!
Its also more attractive to buyers as its just been fully serviced and ready to go.
Also do valve clearances too. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Jayy |
 Jayy Mr. Ponzi
| 0l0dom0l0 |
 Posted: 23:43 - 21 Mar 2011 Post subject: |
I suspect a mixture of everything above is probably the cause.
Have you got a haynes?
If not get one and have a read through. See what you think. Clearances aren't that hard to measure, it just gets a little more complicated if you have to start removing cams to replace shims (but that's only if the clearances are out).
How many miles has it done? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| Jayy |
 Jayy Mr. Ponzi
| 0l0dom0l0 |
 Posted: 23:50 - 21 Mar 2011 Post subject: |
| Recoil Jay wrote: | It's supposed to have 3000 mile interval services. Last service stamped in the book is 9,000 miles. It's done close to 15,000 now without a service. The 12,000 mile service would have been an oil/filter change and the 15,000 mile service should be a valve clearance check as well as oil/filter. |
There you go!
See how you get on with all the servicing and I expect that will sort it! Maybe even the clutch noise if you haven't done it in that long! ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
| MinhDinh |
 MinhDinh World Chat Champion
 Posted: 00:06 - 22 Mar 2011 Post subject: |
Do you have any power at the high revs?
The bike seems to be slipping and getting worse to me. Adjusted the clutch cable to see if it affects anything? If so then unlikely to be the engine etc...
A good service will help anyway. ____________________ Hit the G spot.  |
| Jayy |
 Jayy Mr. Ponzi
| keyser soze |
 keyser soze Scooby Slapper
| Jayy |
 Jayy Mr. Ponzi
The last post was made 15 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
