| Strummer1977 |
 Strummer1977 Derestricted Danger
 Posted: 01:06 - 23 Mar 2011 Post subject: Ouch!! Holed piston!! |
Yamaha RD200 CS5e - Holed piston!!!  |
| Howling TerrorOutOfOffice |
| Strummer1977 |
| Rogerborg |
 Rogerborg nimbA
| Blau Zedong |
 Blau Zedong Banned
| Strummer1977 |
 Posted: 14:08 - 23 Mar 2011 Post subject: |
| BLUEX5 wrote: | A CS5E and an RD200 are two different bikes. Anyway, taking my pedants hat off - you need to be certain why this happened. If the bike is pretty standard then it'll be an air leak (Intake or base gasket most likely) OR wayward ignition timing. Did you set the timing with a dial / height gauge? |
You sir, are of course utterly correct. I stand corrected its a CS5e.
Bike is standard as far as I can see. Only recently purchased. Appeared to have been fully restored. It had recentley had piston and rings as far as I was told.
I believe I had sufficently run it in.
First time I used it on an extended A road run, not utterly thrashing btw but 6000 - 7000 rpm. The above happened. I hadn't detected signs that anything was wrong. Occassionally there was a slight hesitation to pickup if you had been crawling a along at very low rpms, much like a plug getting oiled up. I havent ridden a two stroke for quite some time btw so its possible I missed any tell tale signs, either that or I may just be a muppet !!
As far as I can tell the auto lube was working. It was fully topped up, appeared to be in the pipes leading to the intakes, rear of both exhausts apeared to be slightly oily.
I myself had not looked at the ignition timing, seemed to be running quite sweet. Yes I know I should have checked as a matter of course. Yes I should of had the plugs out sooner ! Hindsight in a wonderful thing!! The other pot looks to be perfect, plug is a nice tan colour. Top of the piston has just started to get a layer of coke on it.
I have got a mechanic mate to hone the bore and it seems to be ok and usable. Its already on 0.50 (50 is stamped on the pistons) oversize pistons. So I'm thinking new piston & rings on the affected side, gap the rings and I should be good to go? I have a gasket set.
Check ignition timing, check for air leaks, somebody suggested removing the auto lube and running on a more oil rich premix?
All ideas / suggestions welcome. Dont profess to be an expert but definatly a two stroke lover. Once I get this going again I can get back to getting my GT380 on the road.
Anybody know where you can get pistons for these in the uk? I see you can on ebay but they are all in the states so obviousley take a while to come.
Thanks in advance ____________________ Owned: 250 Superdream, CD125 Benly, CD200 Benly, Z200, Jawa 350 outfit, CX500, Bandit 600, GY 200 plus other chinese fair. Yamaha CS5e, GPZ 500.
Own: Suzuki GT 380, Loncin JL 250, Yamaha R6 |
| cb1rocket |
 cb1rocket World Chat Champion
| MarJay |
 MarJay But it's British!
 Posted: 15:15 - 23 Mar 2011 Post subject: |
You may need to split the engine and clean out the crankcases. It'll have peppered the small end and crank with blobs of molten alloy.
It's not a lubrication issue. That sort of damage is classic of either running super lean or having the ignition too advanced.
I caught this one just before it hoiled completely:
https://i48.photobucket.com/albums/f216/stinkwheel/piston.jpg
This was caused by the stator plate coming loose and slipping, radically messing up the ignition timing. There were still blobs of molten alloy on the top of the conrod ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Strummer1977 |
 Posted: 15:18 - 23 Mar 2011 Post subject: |
| stinkwheel wrote: | You may need to split the engine and clean out the crankcases. It'll have peppered the small end and crank with blobs of molten alloy.
This was caused by the stator plate coming loose and slipping, radically messing up the ignition timing. There were still blobs of molten alloy on the top of the conrod |
Thats very interesting.
I pretty sure your right.
I was going ask about cleaning out the crank cases. ____________________ Owned: 250 Superdream, CD125 Benly, CD200 Benly, Z200, Jawa 350 outfit, CX500, Bandit 600, GY 200 plus other chinese fair. Yamaha CS5e, GPZ 500.
| Strummer1977 |
 Posted: 15:45 - 23 Mar 2011 Post subject: |
Anybody know if the piston on the Cs5 are the same as used in the RD200? ____________________ Owned: 250 Superdream, CD125 Benly, CD200 Benly, Z200, Jawa 350 outfit, CX500, Bandit 600, GY 200 plus other chinese fair. Yamaha CS5e, GPZ 500.
| Blau Zedong |
 Blau Zedong Banned
| FBSF |
 FBSF Nitrous Nuisance
| Frost |
 Frost World Chat Champion
| Strummer1977 |
 Posted: 14:35 - 29 Mar 2011 Post subject: |
| FBSF wrote: | I had a similar thing happen on my RD125LC three times many moons ago - we checked everything - carb, filters, reeds, exhaust.
Turned out there was a hairline crack in the crankcase, that was allowing air into the mixture causing it to run very lean...
Got it ally welded, and all was good. Just a shame it took us 3 pistons and a lot of roadside collecting (me & bike) to work it out... |
Got some pistons and rings coming. I'm hoping its an ignition timing/air leak issue but I guess we will see. ____________________ Owned: 250 Superdream, CD125 Benly, CD200 Benly, Z200, Jawa 350 outfit, CX500, Bandit 600, GY 200 plus other chinese fair. Yamaha CS5e, GPZ 500.
| Avora |
 Avora Renault 5 Driver
The last post was made 15 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
