Over filled cooling system CBR 600
89CBRChris
PostPosted: 13:27 - 14 Aug 2004    Post subject: Over filled cooling system CBR 600 Reply with quote
Hi,
quick question, is there any real harm in slightly overfilling your cooling system, I think I've put about a 1/4 ltr more in there than I should of and its above the markings shown on the side of the reservoir.
I really need to know if I should try to level it out or whether it should be ok as it is?
Chris
Hex
Party Boy
PostPosted: 14:31 - 14 Aug 2004    Post subject: Reply with quote
If theres too much it wont blow any seals etc like oil may/can. All that will happen is any extra will come out of the top of the system when its under pressure.
Don't worry about it.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 14:31 - 14 Aug 2004    Post subject: Re: Over filled cooling system CBR 600 Reply with quote
Is this the coolant expansion bottle?
If so, it shouldn't really be a problem, but you should be aware that if your system is actually low on coolant you will probably have to fill it up somewhere else as well (ie the radiator).
Not sure if they had coolant expansion bottles that far back though.
89CBRChris
PostPosted: 14:48 - 14 Aug 2004    Post subject: Reply with quote
phew, well thats one less thing to worry about Thumbs Up
thanks for the info, I think it is the expansion bottle I fill up but there is a sticker on it saying only fill it up from here so I guess the radiator get filled through the system.
ProXimaCore
Dougal
PostPosted: 17:27 - 14 Aug 2004    Post subject: Reply with quote
Just checking my oil levels and it's way over the limit from when I refilled it. What would be the physical effects I'd notice if it has done any damage? I'm having some problems just now and I'm looking into every possibility.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
Hex
Party Boy
PostPosted: 11:41 - 15 Aug 2004    Post subject: Reply with quote
Too much oil can blow oil seals around the crank or anywhere in the engine to be honest by the increased pressure that can arise from having too much oil.
Symptoms could be something simple like an oil leak external to the engine or something like oil been used but not leaking (ie been burnt in the cylinders).
The last post was made 22 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 48.72 Kb
