1973 CB450 Twin Honda stalls
KingCustomCyc...
PostPosted: 00:33 - 24 Mar 2011    Post subject: 1973 CB450 Twin Honda stalls Reply with quote
Good evening, my CB450 accelerates at redline in each gear to about 70, begins missing, and then settles in at 50 mph and is smooth again. I cannot accelerate again until the bike has been below 50 awhile, then I can go again until it misses and decels to 50. I have cleaned and tested the fuel petcock, tank, and carbs, new sparkplugs, starts and runs perfect. I have been a mechanic for 35 years and this one has me stumped. Thanks all!
finpos
PostPosted: 00:55 - 24 Mar 2011    Post subject: Reply with quote
Two things you've not mentioned - Fuel breather (which will be built into the fuel cap) and the condenser. Also try different coils if you have some spare.
Not dropped a cylinder when it's lost power has it??
f.
Shreddie
PostPosted: 00:56 - 24 Mar 2011    Post subject: Reply with quote
It does sound like a fuelling problem to me. Hows the fuel filter?
prawny1
PostPosted: 01:00 - 24 Mar 2011    Post subject: Reply with quote
Is your advance unit working as it should? (assuming it has mechanical advance.
hellkat wrote:
KingCustomCyc...
PostPosted: 10:26 - 24 Mar 2011    Post subject: possibilities Reply with quote
Wouldn't rev to redline with advance stuck, coil would not fail and then begin working consistently, fuel tank vent is fine as the petcock drains as new. I am leaning toward a plugged bowl vent on one carb. after sleeping on it. Thanks guys, other ideas welcome.
paddlesat16
PostPosted: 15:10 - 24 Mar 2011    Post subject: Reply with quote
Give the points the once over, might need re-gapping or replacing, and check the timing hasn't slipped.
Check out https://www.hondatwins.net loads of info available here for cb450 etc
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
KingCustomCyc... This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
Casper
PostPosted: 02:24 - 26 Mar 2011    Post subject: Reply with quote
I had this problem with an old GPz550. Turned out to be no air getting into the tank. stick the tank key in the lock if you have a spare and take it for a fast ride. When it starts to die open the cap and if it starts to run fine straight away you know your problem.
gfiandy
PostPosted: 20:49 - 26 Mar 2011    Post subject: Reply with quote
Definately sounds like fuel starvation. If its not an air lock as suggested, could you have a fuel line that is collapsing?
I guess you have already checked that there are not blocked fuel filters. I don't know this bike but mine had some sneaky whitches hat filters just next to the carbs that blocked casing slow fuel delivery.
Regards,
Andrew
ANDY
Odie
PostPosted: 05:12 - 27 Mar 2011    Post subject: Reply with quote
The diaphrams are split in the carbs, common problem from when i had one (years ago!)
The last post was made 15 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 70.77 Kb
