 McJamweasel BCF Junkie
 Posted: 15:55 - 24 Mar 2011 Post subject: Show & Tell - Swapping PC case |
After upgrading my machine in september I decided that it was time to replace my 6 year old Antec Sonata case too. I settled on the Fractal Design Define R3, a gorgeously understated case with good cooling and lots of soundproofing to keep the noise in.
https://www.kustompcs.co.uk/acatalog/1579.jpg
So, first off here is the existing system.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/01Medium.jpg https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/02Medium.jpg
First job was to strip out the cabling, disk drives and the expansion cards:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/03Medium.jpg
Next out came the motherboard and PSU, leaving a rather sad looking, empty case:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/04Medium.jpg
And a pile of components (AMD Athlon X2 250, 4Gb DDR3, MSI 770-C45 motherboard, Gigabyte GTX460 1GB and drives.):
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/05Medium.jpg
Now time for the build up. I started by fitting the fans. There are 4 120mm fans in there, 1 bottom & 1 front on intake and 1 top & 1 rear on exhaust duty. The front is motherboard controlled and the other 3 are run by a fan controller on the case. There's still space for another 120mm in the front and a 120 or 140mm in the roof and in the side panel. The front, floor & PDU intakes are covered with filters, the unused side panel & roof mounts are covered in more sound proofing.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/cooling.jpg
Time for the disk drives next. The hard drives are in these removable trays with rubber supports to damp the vibrations.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/07Medium.jpg https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/08Medium.jpg
Next up was the PSU. The Define has plenty of space behind the motherboard tray for the cabling. The only niggle that I have is that the rubber gromets on the cable holes is a bit soft, so they easily pull out of place when running cables through.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/09Medium.jpg
Now it was time for the motherboard.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/11Medium.jpg
Next up were the Wi-Fi and GPU cards and the cabling.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/12Medium.jpg
Alas, this is the extent of the cable tidying job that I had to do:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/13Medium.jpg
Tidying done. Not the best job, but good enough. I've used rapstrap in places rather than cable ties, they work very well.
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/14Medium.jpg
And the finished build:
https://i152.photobucket.com/albums/s167/McJamweasel/Sonata%20to%20Define/15Medium.jpg
Temperatures are basically unchanged from the Sonata, under load (Furmark for GPU and Prime95 for CPU) I get 72 C for the GPU and 40 for the CPU with all case fans on minumum (room temp 21 C). If I up them to full it only makes a couple of degrees difference so I won't bother, I prefer the quiet.
The Sonata was 2~3 degrees higher with only 2 case fans, so I think that speaks volumes for the cooling efficiency of that (admittedly noisier) case. ____________________ BCF: Be yourself, just don't be an arse. |
 Frost World Chat Champion
 Neorion World Chat Champion
