Brake fluid - cheap or branded?
DrDonnyBrago
PostPosted: 11:45 - 25 Mar 2011    Post subject: Brake fluid - cheap or branded? Reply with quote
Hi, is it worth paying the extra for branded brake fluid?
Looking at cheap stuff and pricey branded stuff, both Dot 4, they have the same boiling point (unless you buy an OTT 'race' spec fluid) and they meet the same standards.
Are there any noticeable differences between the two to warrant the extra money? (corrosion inhibitors, water absorption etc).
Cheers.
PostPosted: 11:55 - 25 Mar 2011    Post subject: Reply with quote
Not sure there is any great difference between a basic branded fluid and a cheapo unbranded one. That is if the branded stuff is only just reaching the specifications.
But how much will you actually save? Not sure the difference would make it worthwhile (unless you are buying 5L cans to use as paint stripper).
You might be able to find a local trade supplier who will sell you a box of branded bottles for a reasonable price. Only trouble then is if you lose the box in the garage........
DrDonnyBrago
PostPosted: 12:15 - 25 Mar 2011    Post subject: Reply with quote
Price is not the issue tbh, more the convenience of being able to walk 100m and buy the cheap stuff or drive to the other side of the city to buy branded.
What do the fluids need to do to meet the various standards? Presumably wet/dry boiling point need to be good and maybe something about viscosity?
PostPosted: 12:36 - 25 Mar 2011    Post subject: Reply with quote
Fairly certain viscosity is specified and colour certainly is (so the ATE stuff that is blue but otherwise the same as their normal stuff but which makes it easy to see whether you have flushed the new fluid through is probably not actually DOT compliant), but not sure what else beyond these basics
Personally, but a stock of small bottles so it is to hand when required (but then I am a hoarder).
Gazdaman
I did a trackday!!!
PostPosted: 12:40 - 25 Mar 2011    Post subject: Reply with quote
I've always used Halfords own brand stuff and never had any issues at all.
Although their fork oil comes in a remarkably similar bottle. Which led to me and a mate on night bleeding his new braided hoses on his R6 with fork oil.
Gaz
alun111
PostPosted: 13:54 - 25 Mar 2011    Post subject: Reply with quote
I use the dot4 that wilkinsons sell. I think it's made buy comma. It's around £2.50 for a 500ml bottle.
Never had any problems.
blurredman
PostPosted: 14:10 - 25 Mar 2011    Post subject: Reply with quote
I wouldn't say walking 100 miles is very convenient Shocked
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 52k.
Bloggsy
PostPosted: 20:29 - 25 Mar 2011    Post subject: Reply with quote
in cars and bikes i've always used carlube dot 4 £2 for 500ml in the range.
Dazbo666
PostPosted: 21:17 - 25 Mar 2011    Post subject: Reply with quote
branded or cheapo, doesn't make much difference to me tbh...
any "dot 4", as long as it's a fresh unopened bottle Thumbs Up
Word of the day : DILLIGAF
Oldie
PostPosted: 21:49 - 25 Mar 2011    Post subject: Reply with quote
Says all you need to know.
jimspeed
PostPosted: 13:06 - 26 Mar 2011    Post subject: Reply with quote
Any DOT 4 should comply with the same requirements really. With the rally cars I just use the cheap stuff we have at work and change it every rally due to the heat it is absorbing and never had a problem with it, I cant see a bike working that amount of heat into the fluid due to lots of factors so the cheap stuff should be good, as said just get a large bottle and renew it every 12 months etc due to moisture absorbtion Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
The last post was made 15 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 71.85 Kb
