when putting scooter on stand wheels spin to top speed!
matto224
PostPosted: 16:36 - 26 Mar 2011    Post subject: when putting scooter on stand wheels spin to top speed! Reply with quote
when putting my scooter on the stand it acellrates on its own
but when i dont have it on the stand its fine? weird..
help please? Question
Paxovasa
PostPosted: 16:38 - 26 Mar 2011    Post subject: Reply with quote
Let go of the throttle Thumbs Up
matto224
PostPosted: 16:46 - 26 Mar 2011    Post subject: Reply with quote
not very helpful lol
Paxovasa
PostPosted: 16:53 - 26 Mar 2011    Post subject: Reply with quote
Is the throttle cable routed correctly?
matto224
PostPosted: 17:07 - 26 Mar 2011    Post subject: Reply with quote
erm well it seems to be fine
and i know but it acellrates to top speed :/
prawny1
PostPosted: 18:34 - 26 Mar 2011    Post subject: Reply with quote
You will have some mechanical friction on the rear clutch assembly but the rear should only spin up if the clutch is spinning fast enough to engage the drum/rear transmission.
Is your clutch drum blue from heat? you could have your idle set to high or the clutch springs could be weak or possibly even a broken spring, or your pulleys are sticking in the higher ratios thus spinning the clutch up to fast at idle,
you realy need to set your idle then if it still drags get the belt cover off so that you can see whats going on.
Your wheel probably won't be spinning at top speed unless your revs are rediculasly high you don't get full variation untill your hitting 30mph or so.
hellkat wrote:
Livefast123
PostPosted: 19:13 - 26 Mar 2011    Post subject: Reply with quote
When you put the bike up on the stand check that it is not fowling any of the rubber tubes eg fuel and that all of the intake system pipework is intact.
Other than that the only two other options will be idle set too high or it's pulling on the throttle cable.
Current ride - Yamaha MT-07
matto224
PostPosted: 23:46 - 26 Mar 2011    Post subject: Reply with quote
hmmm... im completely new to mopeds and i brought this as a project to keep me occupied
and i have a vague idea on mopeds but i dont really know what to do.
i do know that when i start it on the stand the revs increase and the wheel starts spinning like mad...
+ when i take it off the stand it idles fine and it doesnt rev it idles perfect...
i think i need to get a mechanic to take a look as i dont really know what im doing :/
but im thinking maybe its an air leak as there is a crack on the plastic cover which is on the side case which i think is the viaritator cover case?
thanks for all ur great ideas on what might be wrong but its really confusing me :/.
matto224
PostPosted: 23:49 - 26 Mar 2011    Post subject: Reply with quote
i have an idea?
shall i take a video on what happens and post it on youtube and put the link on this post?
let me know guys
Raffles
PostPosted: 00:39 - 27 Mar 2011    Post subject: Reply with quote
matto224 wrote:
i have an idea?
let me know guys
We await with baited breath.
matto224
PostPosted: 14:50 - 27 Mar 2011    Post subject: Reply with quote
https://www.youtube.com/watch?v=GVemRGNBnME
there we go . theres abit more detail in the description
I have only one eye. Do you want me to look at the road or the at the speedometer.
matto224
PostPosted: 15:07 - 27 Mar 2011    Post subject: Reply with quote
yes its really weird... when on the stand it idles high but not really high... when i sit on it, it goes crazy and the wheels spin
but when off the stand it idles perfect
really bloody confusing me!!!
cb1rocket
PostPosted: 15:59 - 27 Mar 2011    Post subject: Reply with quote
def. got to be a cable routing problem. Check where the cable runs cos something is pulling on it
bass2k8
PostPosted: 17:22 - 27 Mar 2011    Post subject: Reply with quote
I think that the idle speed is a bit too high. Try adjusting the idle speed screw on the carb and see if anything happens. It should be a screw with a spring. Try twisting it either way and see if it makes any difference.
Peugeot Speedfight 2 100 Prost, 01 Plate, 2000 model.
matto224
PostPosted: 17:27 - 27 Mar 2011    Post subject: Reply with quote
hmm wheres is this screw?
cheers
bass2k8
PostPosted: 17:32 - 27 Mar 2011    Post subject: Reply with quote
Take a few pictures of your carb for me, and I will try and identify it for you.
Also what scooter do you have?
matto224
PostPosted: 17:34 - 27 Mar 2011    Post subject: Reply with quote
i know i sound completly stupid but wheres the carb?
and a piaggio nrg power
bass2k8
PostPosted: 17:42 - 27 Mar 2011    Post subject: Reply with quote
Mine is located on the left hand side of the bike, near the rear wheel. Do you know what a carb looks like? Heres what mine looks like:
https://img13.imageshack.us/img13/2497/img20110326175940.jpg
You see the silvery flat-head screw with a spring... thats the idle speed screw. Look for something similiar on your ped.
matto224
PostPosted: 17:45 - 27 Mar 2011    Post subject: Reply with quote
ohh thank you Very Happy i know what you on about now ! Smile
is it anti clockwise to lower the idle speed?
ill try this in a couple of days because at the moment ive got no oil and i dont want to damage the engine Sad
thanks mate
bass2k8
PostPosted: 17:52 - 27 Mar 2011    Post subject: Reply with quote
If I'm perfectly honest I cannot remember which way to turn it haha... you will have to try this out yourself... don't worry about over doing it because you have to twist it in quite a lot to adjust the RPM's on idle.
Haha thats cool... keep us up to date Smile This stuff really interests me Smile
matto224
PostPosted: 18:32 - 27 Mar 2011    Post subject: Reply with quote
ive found the carb and the idle speed... ill try and sort it when ive got some oil in my scooter Smile
ill keep you posted
The last post was made 15 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 117.55 Kb
