What voltage should my battery be?
GREENI3
PostPosted: 20:00 - 27 Mar 2011    Post subject: What voltage should my battery be? Reply with quote
When the engines idling the horn sounds really weak but works perfectly on full throttle when the alternator kicks in, so I thought the battery might need a charge.
Also the brake light doesn't get brighter when I pull in the brake leaver and the brake light blinks in sync with the indicators when they're on.
So I've taken the battery out and tested the voltage which is 6.99v.
My question is should the voltage of the battery be 12v when it's disconnected? or does it mean when the throttle is fully open that the batterys voltage should then read 12v?
And how long can I leave the battery out for before it discharges and how long should I charge it for?
0l0dom0l0
PostPosted: 20:28 - 27 Mar 2011    Post subject: Reply with quote
Should be around 13.4V when fully charge IIRC. At around 14V when the revs are held at 4k or so.
Will take forever to completely discharge but to get to the state its in now from 13v a fair few months if its a good battery. Dads bike started after 3 months no issues.
Charge it over night. Measure the voltage across it after you take the charger off.
do you do loads of short journeys? Im surprised the bike even starts with 7v across it!
GREENI3
PostPosted: 20:46 - 27 Mar 2011    Post subject: Reply with quote
Can I use a trickle charger to get it back up to 12v?
Shreddie
PostPosted: 20:49 - 27 Mar 2011    Post subject: Reply with quote
With a brand new battery at least... Anything around 12.8V is fine for an older battery.
You and me both!
PostPosted: 20:55 - 27 Mar 2011    Post subject: Reply with quote
This link has some good battery information.
https://www.totalmotorcycle.com/maintenance/battery.htm
Last edited by Howling TerrorOutOfOffice on 21:04 - 27 Mar 2011; edited 1 time in total
GREENI3
PostPosted: 21:02 - 27 Mar 2011    Post subject: Reply with quote
Btw thats starting it on the kick start. I'd be lucky to even get a noise from the electric start. Laughing
So would I be able to use a trickle charger to get it back up to 12v?
0l0dom0l0
PostPosted: 22:24 - 27 Mar 2011    Post subject: Reply with quote
Yeah as long as its a 12v charger a trickle charger is good!
McJamweasel
BCF Junkie
PostPosted: 22:32 - 27 Mar 2011    Post subject: Reply with quote
As long as the battery isn't bollocksed, which I suspect it will be if it's only holding 7v.
0l0dom0l0
PostPosted: 22:37 - 27 Mar 2011    Post subject: Reply with quote
Possibly, but it is still worth a shot!
The last post was made 15 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 60.67 Kb
