Bandit rear pads
sparkywilliam...
PostPosted: 22:09 - 27 Mar 2011    Post subject: Bandit rear pads Reply with quote
Just put nearly new brake disc on the back and levered apart old pads,greased pins and reassembled and as rear while spins they are very slightly rubbing at one point,if I run her for a while will the pad material erode without damaging my new disc?
Incidentally one of the pins is impossible to get out,used plus gas,pliers,it won't move,I know this is very common but apart from heat I can't think how to get it out.
Finally has anyone got a good condition chain I can buy.
Thanks
Previously CG125,YBR125 Now GSF600 Bandit
Paxovasa
PostPosted: 10:52 - 28 Mar 2011    Post subject: Reply with quote
The pads need to bed in.
As for getting the pins out, a little heat, mole grips and a hammer. Thumbs Up
dragstaar
PostPosted: 11:11 - 28 Mar 2011    Post subject: Reply with quote
I veeerry carefull used a fine nozzle blowtorch to heat up the caliper, then sprayed brake cleaner on just the pin to make it contract and gave it a good yank with mole grips and they came out. Defo the way to do it. But yeah, they're such a pain in the ass.
sparkywilliam...
PostPosted: 11:38 - 28 Mar 2011    Post subject: Reply with quote
ok thanks guys-heat looks like the way.
i wouldn't normally be a skinflink and would replace chain/sprockets as a kit but i will be trading it in for something bigger soon so not bothered about spending too much money - so if anyone can recommend where i can buy a near new chain i'd appreciate it although i'm finding ,because people do replace the lot,that chains on their own are difficult to source.
Paxovasa
PostPosted: 11:47 - 28 Mar 2011    Post subject: Reply with quote
https://cgi.ebay.co.uk/Suzuki-GSF-600-BANDIT-X-Ring-Chain-1995-1999-/150579923198?pt=UK_Motorcycle_Parts&hash=item230f4348fe#ht_500wt_1156
sparkywilliam...
PostPosted: 12:04 - 28 Mar 2011    Post subject: Reply with quote
Ah thanks bud,
So i presume the same chain that fits the pre-2000 will also fit MK2?-i wasn't sure.
And with this i don't need a chain tool rivet?
PostPosted: 12:09 - 28 Mar 2011    Post subject: Reply with quote
The pins in the rear pads are a pig.
Sometimes helps to split the caliper, as this at least frees off one end of the pins. And if you are lucky the end that is still stuck is the non blind end so you can knock them out. However mole grips on the pins (not just pliers) and trying to rotate them a bit does stand a good chance of working.
DrDonnyBrago
PostPosted: 13:09 - 28 Mar 2011    Post subject: Reply with quote
sparkywilliams wrote:
Ah thanks bud,
That one comes with a both a rivet and a split link although IMO split links should be reserved to smaller bikes only.
Bezzer
PostPosted: 14:33 - 28 Mar 2011    Post subject: Reply with quote
The easiest way to remove a stuck pin in a Bandit rear caliper is to drill a hole in the back and punch it out. Hold the caliper up and line up the pin from a couple of angles to find where the blind hole is, mark and centre punch it then drill a 3mm hole, you'll get a puff of oxide as you break through to the pin then use a punch or masonry nail to knock it out. A 3mm hole is the ideal, the pins are 4.7mm ish in diameter so won't drop through, you've always got the hole then for the next time unless you grease the pins a regularly or replace with stainless ones. It's easy to do, no need to strip the caliper or detach it from the brake line etc, done it loads of times for mates, Suzuki rear calipers are infamous for the stuck pin.
sparkywilliam...
PostPosted: 14:42 - 28 Mar 2011    Post subject: Reply with quote
ok thank you fellas,i know the score now.
sparkywilliam...
PostPosted: 09:12 - 01 Apr 2011    Post subject: Reply with quote
Guys,I'm unsure as to wether I should go for a split link or hard rivet,I like the idea of being able to easily take the chain off and I don't want to spend on a hard rivet tool.
I'd appreciate any opinions?
Bezzer
PostPosted: 11:13 - 01 Apr 2011    Post subject: Reply with quote
There's no real need to remove your chain unless it's for replacement so stick with a rivet, safer than a split link for everyday riding.
DrDonnyBrago
PostPosted: 11:39 - 01 Apr 2011    Post subject: Reply with quote
I wouldn't ride a big bike with a split link in the chain for any extended period.
Buy chain, fit with split link, ride to garage using the split link, get them to rivet the chain properly for you Thumbs Up . If you supply the links they will probably charge somewhere in the region of £5-10 to rivet it for you.
Alternatively, buy a DID soft link chain and use a molegrips and a some hammers to rivet it. It's the pikey way of doing it but it can be done well (see below).
https://www.bikechatforums.com/viewtopic.php?t=185149&highlight=hammer+chain+link
sparkywilliam...
PostPosted: 14:03 - 02 Apr 2011    Post subject: Reply with quote
thanks DonnyBrago,
https://cgi.ebay.co.uk/Suzuki-600-Bandit-2000-2004-Model-O-Ring-Chain-/170544603782?pt=UK_Motorcycle_Parts&hash=item27b5402286#ht_794wt_698
Since i want to check the swingarm bearings i may as well opt to put on the above endless chain afterwards as that is exactly what i have on my bike at the moment.
reckon that a good move?
Bezzer
PostPosted: 14:20 - 02 Apr 2011    Post subject: Reply with quote
I personally wouldn't fit a £30 unknown make chain on a B6, or any other decent sized bike for that matter. You get what you pay for with a chain, as the price decreases the possibilty of failure increases.
dragstaar
PostPosted: 17:56 - 03 Apr 2011    Post subject: Reply with quote
+1
Imagine riding along at 40mph and the chain snaps, this is a big fat heavy metal chain being flung at your leg/spine from behind.
Spinal surgery is far more than a decent chain
The last post was made 15 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 93.69 Kb
