Any mySQL experts?
Jayy
Mr. Ponzi
PostPosted: 14:08 - 01 Apr 2011    Post subject: Any mySQL experts? Reply with quote
I have a slight problem that I'm unable to solve, as I don't know the query I would need to run in mySQL. Basically, I have moved a Joomla site over to a testing server whilst I upgrade the site and it has the HWDvideoshare plugin running. The problem is, on the old server, the site was installed to /joomla and now I've moved it to my testing server, it's in the root directory.
All the video thumbnails are looking for /joomla/hwdvideos/thumbs/ when I need them to be in /hwdvideos/thumbs/
You might think, why don't I just create that folder? If I do that, all the thumbs show up but it causes problems when uploading new videos.
I was thinking all I need to do is a run a mySQL query in phpmyadmin to change all the paths? I changed the first two (ID 12,13) manually and it's all working fine but there's 450 of them...
I've attached a screen shot of the database, does anyone know what query I can run to change every path in the 'thumbnail' table to reflect the right path without the /joomla/ ?
angryjonny
PostPosted: 14:18 - 01 Apr 2011    Post subject: Reply with quote
Dunno about MySQL but (assuming you need the "/" up front) in Oracle it would be:
update jos_hwdvidscategories set thumbnail = substr(thumbnail, 8)
where substr(thumbnail, 1, 7) = '/joomla'
That'll leave the ones that don't start with /joomla alone.
But it's Oracle. Not MySQL. So the answer to your question is "no", I guess.
Whatever you do, run a select first to see what the effect would be.
elky
PostPosted: 14:21 - 01 Apr 2011    Post subject: Reply with quote
I've not got any access to mySQL at the minute, but it should be something like:
UPDATE jos_hwdvidcategories
SET thumbnail = SUBSTR(thumbnail,11,100);
So effectively just deleting the first 11 characters of the thumbnail (100 is just a big number to ensure you capture the full file name)
Do a select first though to make sure you have the sub string set correctly.
SELECT SUBSTR(thumbnail,11,100) FROM jos_hwdvidcategories;
supZ
unfortunately i use mssql not mysql but you will be able to get that done by using a replace command and updating the record.
MS SQL:
Code:
UPDATE jos_hwdvidscategories
SET thumbnail= REPLACE(thumbnail,'/joomla/hwdvideos/thumbs/','/hwdvideos/thumbs/')
i cant imagine the mysql version being much different. have a google Smile
you can of course just replace /joomia/ with / if you want too as the folder structure is the same bar that dir
edit:
just checked myself and it looks like its the same syntax
CBR954RR - Daily toy
CBR600RR - Trackbike
mjn51
PostPosted: 14:31 - 01 Apr 2011    Post subject: Reply with quote
As with the other replies
SUBSTRING(str FROM pos FOR len)
this may help :-
https://dev.mysql.com/doc/refman/5.5/en/string-functions.html#function_substring
Jayy
Mr. Ponzi
PostPosted: 14:37 - 01 Apr 2011    Post subject: Reply with quote
What's the difference between supZ and the other methods?
angryjonny
PostPosted: 14:40 - 01 Apr 2011    Post subject: Reply with quote
Different function, same result, really.
Jayy
Mr. Ponzi
PostPosted: 14:44 - 01 Apr 2011    Post subject: Reply with quote
Good stuff... I'm such a retard, I thought, "I'll backup the database now and run some of these queries". Started clicking on things in the database and nothing was working, 5 minutes later, I was clicking the screenshot I uploaded in this topic Embarassed
Jayy
Mr. Ponzi
PostPosted: 14:52 - 01 Apr 2011    Post subject: Reply with quote
supZ, worked a treat! Saved me about 4 hours of manual labour there! Same to the others, thanks for the help, much appreciated.
Karma
supZ
PostPosted: 15:11 - 01 Apr 2011    Post subject: Reply with quote
np Smile
yeh the other examples basically removed the beginning of the string, getting rid of the extra bit you didnt need (the /joomlia bit) whereas my example replaced the text within the string.
my example will work even if you want to replace/remove some text in the middle of the string. substring can work the same way but you need to define the start and end of the portion of the string you're changing rather than looking for an occurance of the part of the string you're looking for
and LMAO @ the screenshot Very Happy
PostPosted: 15:16 - 01 Apr 2011    Post subject: Reply with quote
Would probably have been easiest to use substring_index:-
Code:
UPDATE sometable
SET somecolumn = SUBSTRING_INDEX(somecolumn,'/joomla',-1)
WHERE somecolumn LIKE '/joomla%'
Or just using SUBSTR:-
Code:
UPDATE sometable
SET somecolumn = SUBSTR(somecolumn,8)
This works as SUBSTR will return the rest of the string if you just give a starting point.
Jayy
Mr. Ponzi
PostPosted: 15:28 - 01 Apr 2011    Post subject: Reply with quote
supZ method worked perfectly, will bare these posts in mind next time I need to do this. I have a good knowledge of mySQL, been developing sites with content management and e-commerce for years but sometimes it goes over my head.
Jayy
Mr. Ponzi
PostPosted: 15:30 - 01 Apr 2011    Post subject: Reply with quote
I posted the same thing on the Joomla forums, it had 160 views in about half an hour and not one person replied.
BCF ftw Thumbs Up
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 75.37 Kb
