Just when you think your luck has run out....
FretGrinder
PostPosted: 12:29 - 02 Apr 2011    Post subject: Just when you think your luck has run out.... Reply with quote
Had an issue with the bike this week where my bike struggled to start a few times, with plenty of bump starts, purchase of a new battery and a nice little surprise at the end!
Here's what happened over the week -
Tuesday
Started bike up to go to leave work on Tuesday morning after finishing a night shift and bike struggles to start. "no problem" I think, it's a bit cold, maybe the battery is a little weak. Get home and park the bike up for the day. Get up around 3pm and hop on the bike to get some ciggies and the bike struggles to start, takes 3 or 4 goes to start it up "hmmmm, what's going on?" Get out my multimeter to check voltages on the battery.
Engine off - 11.9V
Engine on - 12.1V
Rev to 3000 RPM - 13.2V
Not good.
I decide to replace the battery as it's had a rough time all through the winter and it's probably on it's way out as the bike is almost 4 years old.
Battery charges fine and I'm good to go to work.
Wednesday
Start bike up to leave work, go to asda (about 3 miles away) to get some stuff for breakfast. Bike struggles to start (oh no, not again)
Get home check out the voltages and they are roughly the same.
This is when I realise, after a few more tests, that it's the reg/rec is definatley the cause.
Put the battery on charge again and leave it all day. At round 8.30 I fit the battery and try to start the bike, starts fine. Get ready to leave for work, start bike, into first, cuts out.
Bollocks!
After many attempts to restart the bike, I've had enough and start chucking spanners around the garage in rage. The I realise I'd left the side stand down while trying to put it into gear!
Now the battery has been flattened. I jump start it with my dads car. On the way to work I realise I'm out of fags and pull into the nearest garage. Now, do I leave it running and run in to get some fags or turn it off. I turn it off as I don't want anyone to nick it. Get fags, run across the forecourt, with lots of bemused faces watching me bump start the bike, and head off.
Thursday
Bump start the bike to get home, searched around on the internet for a pattern reg/rec but, after much searching, there is only pattern parts for varadero's up to 06 and mines an 07. I wait till around 9am to phone the dealer. After a quick chat they tell me they can get me in at around 3pm.
Awesome!
I grab a couple of hours kip and set off to the dealer which is about 25 miles away. I leave the bike with them and after an hour I go back in to be told that it's definatley the reg/rec and I'm looking at £177 just for the part. The bloke that was dealing with the bike told me to leave it with him for about half an hour. Off I go again, and when I come back I'm told that a new one has been fitted and that it won't cost me a penny as I only bought it off them in October last year and, even though it's been out of warranty for a few months, he'll sort it out with Honda.
I'm considering going back with a case of beer for the bloke at the dealer that's bent over backwards, twice, to help me out with the reg/rec and the fork seals. You don't get customer service like that very often.
The bike is now performing just as good as when I first got it, just in time for the nice weather.
Yamaha MT-09
ಠ_ಠ
mr-inteligent
PostPosted: 12:49 - 02 Apr 2011    Post subject: Reply with quote
You did ok in the end then Thumbs Up
but why would you even think about paying £177 for a reg/rec?
FretGrinder
PostPosted: 12:57 - 02 Apr 2011    Post subject: Reply with quote
I couldn't find one anywhere on the internet for any cheaper, my only other option was to mod one from another bike to fit mine. I didn't fancy doing that though in case I'd fucked it up even more.
As I said, the varadero's up to 2006 had a different reg/rec (a 5 pin connector on the reg/rec) and pattern parts are readily available. Mines a hardwired one with a long 2 pin lead to the battery side and a shorter 3 pin lead from the alternator. I couldn't find one anywhere Sad
Still, with a stroke of luck I got it sorted with a new one for nothing! Mr. Green
Yamaha MT-09
ಠ_ಠ
PostPosted: 13:03 - 02 Apr 2011    Post subject: Reply with quote
With service like that I think you should at least name the dealer as he seems to be one of the good guys Thumbs Up
Paxovasa
PostPosted: 13:04 - 02 Apr 2011    Post subject: Reply with quote
Did you buy the new battery from the same dealer?
MinhDinh
PostPosted: 13:12 - 02 Apr 2011    Post subject: Reply with quote
Honda reg/rec seem to go from a lot of their range. :s
Glad you got it all oK!
Hit the G spot. Wink
FretGrinder
PostPosted: 13:17 - 02 Apr 2011    Post subject: Reply with quote
Nope, got that from one of the local bike shops.
Yamaha MT-09
ಠ_ಠ
Ichy
PostPosted: 13:28 - 02 Apr 2011    Post subject: Reply with quote
Sounds like a decent bloke, name the shop.
FretGrinder
PostPosted: 13:31 - 02 Apr 2011    Post subject: Reply with quote
Ok, the dealer is Honda Shreswbury.
On a side note is there anyway of fitting a voltage readout display without too much modding of the dash? I've seen people mod LED's into the dash, but I'd rather not drill into it.
Yamaha MT-09
ಠ_ಠ
Paxovasa
In that case that was good service (unless they has been a recall of them). Wink
keggyhander
PostPosted: 14:11 - 02 Apr 2011    Post subject: Reply with quote
Bit of advice on batteries.
Check out MOTOBATT.
Here's a test of five top AGM batteries and the performance of the Motobatt is startling. It's the only bike battery that can start a American 6.8 litre V10 pickup truck 50 times on the trot:
Part 1) https://www.intruderalert.com/cafe/index.cfm?page=topic&topicID=157926
Part 2) https://www.intruderalert.com/cafe/index.cfm?page=topic&topicID=176271
My bike's original battery died just before Christmas and I did a bit of research before laying out money. On the strength of the above tests I settled on the MOTOBATT because of how many times it will start an engine before running down, and how long it can be left without discharging.
I got mine off Ebay.
The last post was made 15 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 72.23 Kb
