My Bike is dying !!! Please Help me
rizo-sri200
PostPosted: 20:45 - 15 Aug 2004    Post subject: My Bike is dying !!! Please Help me Reply with quote
pot 1 doesnt run under 3k rpm but above shes sweet as a nut
done the following:
check plugs
Adjust plugs
swap leads
swap caps
check coils with haynes
change coils around
swap coils with different set
balanced carbs at 3k rpm
cleaned pilot and main jets
all to no avail Confused
any idea what to do??
Kev? are you the man?
swift kick to the wing mirror puts em straight..
98' Bandit 600 with Slip on
PostPosted: 21:34 - 15 Aug 2004    Post subject: Reply with quote
I would be tempted to check the compression, mainly to see if it is substantially different on the cylinder that isn't working.
When were the valves last adjusted?
rizo-sri200
PostPosted: 21:51 - 15 Aug 2004    Post subject: Reply with quote
the valves havent been done
the bike has only 7000miles on the clock
i did have a thought that it could be a blocked passage way in the carb??? maybe
anyway thanks for the tip kickstart.
iCraig
PostPosted: 23:05 - 15 Aug 2004    Post subject: Reply with quote
Told you that you should of gone for the GS500 Razz.
PostPosted: 00:39 - 16 Aug 2004    Post subject: Reply with quote
Depends on its life, but the valves might want adjusting but are unlikely to be far enough out (in that time) to cause this kind of problem.
Yes the problem could be with a blocked jet in a carb, but you have cleaned them out. Might be worth trying again.
aqualung1
PostPosted: 00:55 - 16 Aug 2004    Post subject: Reply with quote
i would go for checking carbs, does sound as iff pilot/slow running jet blocked
have you checked for muck in carbs as well, have you picked up bad fuel
you say you have checked plugs, have you swapped tham for new? or swapped them over, a test spark does not always mean a full spark in cylinder
good luck
bugsy46
Village Idiot
PostPosted: 01:04 - 16 Aug 2004    Post subject: Reply with quote
hey! aint there another section for this thread?! Thinking
take your bike to a mechanic and get it sorted out
mama mia Praying
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
The last post was made 21 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 54.31 Kb
