| nsr125YRH |
 nsr125YRH Derestricted Danger
| Willson |
 Willson Traffic Copper
 Posted: 19:21 - 03 Apr 2011 Post subject: |
NSR is a two stroke yes?
Not massively clued up on them but I believe there could be something to do with the exhaust.
A nice little animated picture below, but basically the engine will work more efficiently if it's not blowing out fuel/air mixture.
https://www.instructables.com/image/FCPAPL1F8QANFPB/Two-Stroke-Theory.jpg ____________________ Benson: Wouldn't life be easier if we were all turtles?
Me: Pig on bread = The way forward.
Riding: '00 Suzuki SV650S. Previous: '99 Kawasaki ER5 - sold, '02 Suzuki GZ125 Marauder - sold |
| Nope. |
 Nope. World Chat Champion
| anthony_r6 |
 anthony_r6 World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 20:12 - 03 Apr 2011 Post subject: |
UK NSR would be restricted in the exhaust and the intake. Older Italian market one would be totally unrestricted as standard. However even restricted it should easily do more than 65mph, with the exception of those for some markets restricted to low speeds (some German market ones for example).
First thing I would suggest is give the bike a good service and check the compression.
| UKRedwing |
 UKRedwing Trackday Trickster
| nsr125YRH |
| Kickstart |
 Posted: 20:37 - 03 Apr 2011 Post subject: |
You test the compression using a compression tester (basically a pressure gauge that latches the reading and screws into spark plug hole). Should be 143psi give or take 28psi (from memory).
The NSR doesn't have a specified service interval for the changing of the rings, and compared to the RS125 the rings are pretty long lived. But they will eventually wear out.
And yes low compression can lose you loads of power.
| UKRedwing |
| skatefreak |
 skatefreak World Chat Champion
| UKRedwing |
| Kickstart |
 Posted: 07:45 - 04 Apr 2011 Post subject: |
Honda do not list the rings being changed as a service items at all. Does list exhaust port and cylinder head decarbonisation at 5k.
Think people on here have done 30k on an NSR without changing the rings.
The NSR has an extra bridge piece across the exhaust port which I suspect gives the rings a FAR easier life than those on an RS125 or Mito (probably at the expense of a tiny bit of power).
| lozza |
 lozza Nova Slayer
| alains |
 alains World Chat Champion
| nsr125YRH |
| lozza |
 lozza Nova Slayer
| nsr125YRH |
| Kickstart |
 Posted: 20:27 - 04 Apr 2011 Post subject: |
The things Alains mentions are going to get the bike running better than standard if it is in good condition. Maybe a couple of mph increase in top speed. Not going to account for the ~30mph you bike is down on top speed.
Spark plug is probably not going to give you much. Long before it would have lost you 30mph the bike would probably be unable to start.
| nsr125YRH |
| Kickstart |
| lozza |
 lozza Nova Slayer
| nsr125YRH |
| Kickstart |
| nsr125YRH |
| lozza |
 lozza Nova Slayer
 Posted: 20:48 - 04 Apr 2011 Post subject: |
https://www.mediafire.com/?i5724g515r0o1wo
says JC20 but all the important stuff applies to the JC22 as well.
find the powervalve calibration bit.
the valve is controlled by an electric motor. look between the tank and the frame on the right hand side of your bike, just in front/under the air box theres a small plasic block with a metal pulley on the top and two cables around the pulley.
basically start the bike, warm it up first because youll need to rev it up past 7000.
it should stick at one position, then move when you go over 2000 rpm. then start to move back to the original position once you pass 7000rpm. it moves gradually at this point i think to rev it all the way up to about 10 to make sure. |
The last post was made 14 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
