GoPro 3D
PostPosted: 19:15 - 04 Apr 2011    Post subject: GoPro 3D Reply with quote
Clicky
Drooling
Rowey
PostPosted: 20:53 - 04 Apr 2011    Post subject: Reply with quote
Blimey! That is a proper piece of geek porn.
A little over $600 for the pleasure though.
ZX6R C6F.
colin1
Captain Safety
PostPosted: 21:37 - 04 Apr 2011    Post subject: Reply with quote
It looked like US$ 99.99 to me.
Frost
PostPosted: 21:47 - 04 Apr 2011    Post subject: Reply with quote
Thats probably for the case, then 250 for each camera or something. You can do 3d yourself just using 2 webcams.
colin1
Captain Safety
PostPosted: 22:10 - 04 Apr 2011    Post subject: Reply with quote
Ah I get it now, the 99 I saw, its the kit you need to connect two cameras together. So you add the price of two cameras to that.
You may be able to stream video with webcams, but synchronising them to produce recorded video would be tricky, and the go pros are decent cameras judging by n3o's fisheye footish from a while back that got him convicted.
Frost
PostPosted: 23:11 - 04 Apr 2011    Post subject: Reply with quote
You just pull the data from both cameras at once, It's far easier than trying to start 2 physical cameras at the same time, store it in flash then recombine it later.
colin1
Captain Safety
PostPosted: 23:58 - 04 Apr 2011    Post subject: Reply with quote
I guess you could run two webcams from a laptop and be out and about, but it's quite bulky, which is why people usually use cameras designed for the purpose to fit to their bike, helmet, whatever.
Frost
PostPosted: 01:29 - 05 Apr 2011    Post subject: Reply with quote
You could do it with 2 of those key chain cameras but you'd have to show them both the same even like you clapping your hands to be angle to synchronise the footage. You'd also have to keep them both parallel and at a constant distance appart. Maybe someone should give it a go and get some 3d riding footage. Maybe 3d cat & fiddle?
Rowey
PostPosted: 10:29 - 05 Apr 2011    Post subject: Reply with quote
As I read it, $99 was for the 3D case to combine two cameras and the software to combine the footage.
If you could get hold of the GoPro 3D footage combining software, and record in the same format the go pro's do, I'm sure you could use that to combine the footage from two MD80's. Making a bracket would be tricky, as Frosty said, you'd need to be very precise on the angle and distance apart of the lenses. But it's perfectly doable with a good machine shop and a few hours of tweaking.
ZX6R C6F.
The last post was made 15 years, 175 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 57.88 Kb
