Squeaky brakes
Auzfest
PostPosted: 22:29 - 05 Apr 2011    Post subject: Squeaky brakes Reply with quote
Just had a calliper rebuild and had new pads fitted on bandit and brakes squeak when any amount of pressure is applyed. Is this normal for new pads or is it likely to be caused by something else?
neil.
PostPosted: 08:53 - 06 Apr 2011    Post subject: Reply with quote
Try smearing copper grease on the backs of the pads - will stop them resonating which is likely to be causing the squeaky sounds, or so the theory says. Also clean out your disc if it's got holes in, get a drill bit that matches the diameter of the holes and get rid of all the crud that builds up. Thumbs Up
andym
PostPosted: 13:19 - 07 Apr 2011    Post subject: Reply with quote
if it's the old pads you are still using try putting swapping them over (left one on the right side etc), try giving them a little sand with rough paper to remove the top layer of pad.... maybe try giving the disk a light rub too.
I've done the sanding part a few times and it works better than brake cleaner
The last post was made 15 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.2 - MySQL Queries: 13 - Page Size: 35.41 Kb
