| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| 0ddball |
 0ddball World Chat Champion
| Bezzer |
 Bezzer World Chat Champion
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 17:57 - 06 Apr 2011 Post subject: |
Do you mean:
A) putting the handlebar clip ons BENEATH the top yoke, as opposed to above it......
OR
B) Unclamping the fork yokes, and sliding them further down the Fork Tube
A) changes your riding position in relation to the bike, tipping you more forward into a more pronounced racer crouch.
Depends whether clip ons would 'sit' beneath top yoke given casting shape. How low they'd go, and whether cable routings etc would let you do it, AND let bars still go lock to lock.
Given Honda castings, probably more likely to be successful changing riding position swapping OE Clip Ons for after market adjustable ones.
B) Changes steering geometry, ride height and bike 'attitude'.
Slightly shifts weight lower and further forward, steepens rake angle, reduces trail, generally makes handling a bit more nervous.
Old racing addage, 1/4" at the front is worth 1" at the back, vis a vis dropping nose against lifting rear... ie effects similar to a jack up kit.
Not done OE clip ons beneath joke, have done plenty of alternative bars. It often does little for handling, but if it makes you more comfortable, then why not. As often though, makes folk less comfortable, reduces control and visibility.
Done dropping & lifting to death on different bikes over the years, depends what you want. On race bikes we'd change the fork height in the joke routinely for different tracks, different conditions or different suspension 'settings' (in the day you made them by changing springs or adding shims, rather than twiddling knobs!)
My CB750's pretty soggy as stock, so set up I have on that's pretty radical. Its jacked 4"+ at the back curtecy of over length shocks, and dropped about 1/2" in the yokes...... but that's afetr some seriouse suspension firming. It has progressive wound springs and heavier fork oil up front, shimmed and re leveled, at the back heavier rate dampers and much heavier rate springs, but with very little pre load....... Handling is some what more 'composed' and slightly more spirtited than 'standard', but its a rather single minded set up for my riding style.
Its something you have to mess with a lot to get right, takes a lot of fiddling, and if you start swapping shocks and springs and 'stuff' to find what works for you, expensive! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Old Git Racing |
 Old Git Racing World Chat Champion
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| UnknownStuntm... |
| Teflon-Mike |
 Teflon-Mike tl;dr
The last post was made 15 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
