how much oil
luketapis
PostPosted: 14:22 - 06 Apr 2011    Post subject: how much oil Reply with quote
Hi I am trying to change the oil in my Suzuki Marauder 125 gz, I know that normally I would need about 4L of oil but strangly on the engine its say:850 ml. Dose it quantity of Oil which my bike needs? Its not to less?
FBSF
PostPosted: 14:36 - 06 Apr 2011    Post subject: Reply with quote
It's only a single-cylinder 125, I would have thought that 850ml isn't that far out.
My CM200 twin takes 1.3L, and my GS500 twin takes 2.9L ...
EDIT - just seen a spec for the GS125 which I think has the same engine, and it is 850ml.
Might be worth finding a service manual though, just to be sure...
luketapis
PostPosted: 14:48 - 06 Apr 2011    Post subject: Reply with quote
thx for ur answer. Unfortunately I don't have a manual for this bike.
FBSF
PostPosted: 15:01 - 06 Apr 2011    Post subject: Reply with quote
If the engine says 850cc, then that would be correct if you are changing the filter.
It may take a little less if you aren't changing the filter - I would start with about 800ml, put the filler cap back on, turn the engine over for 5 seconds, turn it back off and then wait 30 seconds, and check the level, adding more 25ml at a time until you reach the right level.
You should be able to check the oil level either with a dipstick that is part of the filler cap, or through a sight glass that will be on the engine casing, near the bottom.
Maverick Rigger
PostPosted: 21:57 - 06 Apr 2011    Post subject: Reply with quote
My Yamaha YBR 125 only takes about 1 litre.
luketapis
PostPosted: 12:34 - 07 Apr 2011    Post subject: Reply with quote
Thanks I will do the way you told me FBSF. Thanks again for the help and regards Very Happy
andym
PostPosted: 13:14 - 07 Apr 2011    Post subject: Reply with quote
my 125 still takes the best part of 2 litres Sad (1800 ml)
I'm building up quite a collection of used oil now Smile
Anyway to the OP what it says on the side is right, but stop short as already pointed out and top up as required
The last post was made 15 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 49.87 Kb
