| Hawke |
 Hawke Derestricted Danger
 Posted: 16:54 - 06 Apr 2011 Post subject: Unwilling to start after a long break, who knows! |
I've had a look around and can't find much helpful advice on the problem i'm having, so though i'd give it a whirl on here
Basically, I've got a 2004 Honda CBR125R that wants to be sold. It's about time I move up in the biking world. However, after a long winter without any use, due to me being away, I came back to find it unwilling to start. Now, i don't exactly know my way around the mechanics of a bike too well, but give me the tools and i'll give anything a go
The symptoms:
The bike turns over happily, the battery is perfectly fine, has had a nice trickle charge going.
Occasionally (meaning once every couple of seconds) when turning over, it will fire. Not enough to get it running.
Once or twice, it has actually managed to run after a fair bit of encouragement, however it cut out as soon as i let the revs drop.
(hope i've got the whole 'turn over/fire' etc lingo right, not that experienced )
What I've done so far:
I've checked the spark plug and cleaned it up. Was black-ish on inspection but cleaned up reasonably well without much effort.
Given it some fresh fuel, in case it had gone off or whatever the hell fuel does when you leave it for too long.
From what I can gather on research into it, it may be something to do with the carbs 'gumming'? Or that might be a stupid suggestion, as I said, i'm not the most knowledgeable person on the subject. May have missed something obvious!
Anyways, enough rambling. If you can offer any help whatsoever, it would be much appreciated!
Thanks  |
| N cee thirty |
 N cee thirty Banned
 Posted: 16:58 - 06 Apr 2011 Post subject: |
clean the carb,new plug  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| CaNsA |
 CaNsA Super Spammer
| MarJay |
 MarJay But it's British!
| CaNsA |
 CaNsA Super Spammer
 Posted: 17:42 - 06 Apr 2011 Post subject: |
fair enough
lets try,
petrol? not diesel? |
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 17:43 - 06 Apr 2011 Post subject: Re: Unwilling to start after a long break, who knows! |
| Hawke wrote: |
Well, if it's an iridium plug, that's shagged it out right there: they're uber-sensitive to even the mildest abrasion (presuming you used something rougher than a cloth, of course). New plug should only cost a couple of quid.
Either way, have you checked the spark? remove the plug, plug it back into the HT lead, and them hold the threaded part of it on to any exposed (i.e. unpainted) part of the frame. Turn the engine over. You should get a fat blue spark - if it's anything other, then it wants replacing.
It's also worth testing the HT lead for continuity, and that the coil is still sound, as well. Do you have a multimeter?
If you're intending to clean the carb, as would be the next logical step after checking the air filter, then don't be tempted to jam anything down the jets to unclog them. soak them in petrol overnight, and put them back in on their original setting (either check the service manual, or count how many turns it takes to screw them in fully - be gentle, though: you're dealing with very soft metals there).
:EDIT: - also, have you drained the float bowl? Emptying the tank's all well and good, but it'll still be trying to draw the old fuel out from there, first. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| Hawke |
 Posted: 18:12 - 06 Apr 2011 Post subject: |
That's some great advice right there, thanks nowhere
Was sure it was a spark plug problem, made sense, but just tested it like you said and it seems to be sparking fine ok, so the spark seems white to me and not blue, but that's hardly a game-breaker is it
Air filter first? think that could be an issue? and ah you've bring up a good point, never drained the float bowl...told you i was rookie  |
| nowhere.elysium |
The last post was made 15 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
