Brake bleeding, a simple soulution?
Stalk
PostPosted: 20:33 - 06 Apr 2011    Post subject: Brake bleeding, a simple soulution? Reply with quote
Hello all,
Having read on here a few cases of people having problems bleeding brakes, and being aware that air goes up and the (front) brake pipe goes down, I decided to try something.
I have just replaced the front caliper seals on the Divvy and it was time to bleed.
I had this:https://motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=91&Ct=CN&SbCt=BA_15_91_CN_30&spPage=3
Second item down. Its a syringe if you don't want to click.
Hose attached to end of syringe and onto the bleed nipple and used the syringe to draw the old fluid out. Filled up with fresh fluid and pumped the brake leaver whilst using the syringe to provide a vacuum on the bleed nipple so stopping the master cylinder drawing the fluid back when it was released. Worked a treat.
Sorry I did not take pictures, hope this might help someone out.
Cheers,
Stalk
cb1rocket
PostPosted: 21:30 - 06 Apr 2011    Post subject: Reply with quote
yes the syringe method works well, although I reverse bleed. You pump the fluid in from the caliper end and thus pushes the air up and out the reservoir. The usual method is then used to squeeze the remaining air and then bungee the lever back over night - job a good 'un Thumbs Up
GSTEEL32
PostPosted: 21:59 - 06 Apr 2011    Post subject: Reply with quote
Agreed ^
Reverse bleed with a syringe, once you see the last of the air making an appearance in the reservoir, job's pretty much a good 'un.
I f**king hate bleeding brakes, it's a proper $hit job, but this is the best way I've found of getting it out of the way.....
Coveman
PostPosted: 23:52 - 06 Apr 2011    Post subject: Reply with quote
I too reserve bleed. I remember a time when I didnt think of it and I was there for an hour just pumping the lever to get the air out.
Put 100ml of brake fluid into a syringe and pushed it through the bleed nipple and it was done in minutes.
Scott
molex
PostPosted: 05:19 - 07 Apr 2011    Post subject: Reply with quote
It's a good choice
About the "Fluid syringe 60ml" GBP $4.00 Very expensive!?
I buy myself HKD $15.00
GBP $4.00 x 12 = 48.00
Good Luck
The last post was made 15 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 43.39 Kb
