suzuki bandit running poor in wet conditions
dayboy
PostPosted: 21:17 - 07 Apr 2011    Post subject: suzuki bandit running poor in wet conditions Reply with quote
hello there i was wondering if anyone could help me!!
i have a suzuki bandit 600 1996 and in wet conditions runs very badly and is sometimes difficult to start but in dry conditions starts and runs fine. Also does anyone no how to sort out the heated carbs on them as mine dont work.
thank you.
temeluchus
PostPosted: 01:10 - 08 Apr 2011    Post subject: Reply with quote
the ht leads and caps on the outer two cylinders are vulnerable on these bikes, pull the caps off, and take them off the leads. may be a bit rotten and you may need to cut the leads back a bit to get fresh copper.
clean the contacts on the top of the caps. when you reassemble its worth packing the tops of the caps with vaseline, and once its all back together, spray the exposed bits with some ignition sealer. holts damp start is a good one.
The last post was made 14 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 35.97 Kb
