| sunnyj58 |
 sunnyj58 Two Stroke Sniffer
| FBSF |
 FBSF Nitrous Nuisance
| sunnyj58 |
| chris-red |
| sunnyj58 |
| Kickstart |
 Kickstart The Oracle
| Livefast123 |
 Livefast123 Nearly there...
| FBSF |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 13:20 - 08 Apr 2011 Post subject: |
Make a moped do more than 32mph & its no longer a moped.
Doesn't meet the C&U regs which stipulate it cant do more than 32mph....
If its registered as a MOPED, then technically you need to present it for VOSA inspection for re registration as a motorcycle......
Must meet regs as a motorcycle, and be insured as a motorcuycle and ridden on a motorcycle licence, EVEN though its still only 49cc or less, its a motorcycle, NOT a moped, and them rules apply.
Riding a de restricted moped is daft....
Pretty obviouse if you get clocked at 40 its not restricted, then they can chuck the book at you for 'riding other than in accordance with your licence', plus invalid insurance, plus obtaining insurance by deception, plus riding a vehicle in 'unroad worthy condition' (not meeting C&U for vehicle type, plus failing to declare changes to DVLA....
They can pretty much pick the bike up and chuck it in a crusher before your eyes, THEN nail your arse to the wall with fines and licence endorsements.....
ALL on the 'evidence' of a speed gun......
Really think its worth it?
Oh, and if you have a car licence that does NOT automatically give you entitlement to ride a moped.
Hasn't done for at least ten years, so if you are twenty one, unless you somehow managed to get your car licence aged ten, you need at least a CBT certificate to 'activate' moped catagory on your car licence, but more likely merely the 'provisional' entitlement, so should also be on L's......
As said, leave it standard or buy a 125..... and if needs be, CBT ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| chris-red |
| sunnyj58 |
| Kickstart |
 Posted: 17:18 - 08 Apr 2011 Post subject: |
CBT for a 50 and a 125 are exactly the same. You can only carry a pillion with a full license whether it is a 50 or a 125. You can ride a 125 on a CBT just like a 50, and you need a new CBT every few years on either.
Sports exhaust can make a difference (but likely makes most difference to noise). However likely by moving peak torque further up the rev range (so making more power as power = torque x rpm), so you might well land up needing to play around the the weights in the transmission to take advantage of it. No point in producing more power at 12k if the transmission won't allow enough slip to get the revs that high.
| Nope. |
 Nope. World Chat Champion
 Posted: 17:28 - 08 Apr 2011 Post subject: |
Right, I think the OP is informed enough now about alternative options to his mode of transport, so lets actually answer his question.
There are a few things that you can do to make a moped 'go faster' without serious modding or money. First thing to do is to buy a sports exhaust, on a budget id suggest a Leo Vince ZX, its an OK exhaust and does what it says on the tin. Get the chrome one because the non chrome rusts like hell. Remove the washer restrictor at the top of the down pipe and your good too go. Bolt that one onto the cylinder in replacement of the stock one and upjet the carb 3%-5%. You'll also need to change the rollers and fit tighter clutch springs, If you don't have an impact wrench and a Clutch bell holder around its probably best to get a garage to do the whole thing (You provide the exhaust), it should only be a couple hours labour. Whatever you do, dont buy a technigas exhaust, there not worth the money, spend the extra money and get a decent brand.
That should take your top speed up slightly, you'll probably see 60 out of it on the speedo, 55 in reality.
You could of course go further, you could fit a big bore kit, expensive sports pipe (Like a Yasuni Carrera) and so on, but if you cant afford a 125 I doubt you can afford that. The exhaust is £300 on its own!
A couple of words of warning though, 'Tuning' High mileage machines is always a risk. Considering its a 2002 I would seriously think about the reliability of it before you undertake this endeavour, you could end up with a piece of crap that breaks down all the time. Also, as said above, riding a derestricted moped makes it no longer a moped, it makes it a motorcycle. That means that you run the risk of a few points on your license and the moped being crushed.
Good luck with whatever you decide to do. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| sunnyj58 |
| Kickstart |
 Posted: 15:57 - 09 Apr 2011 Post subject: |
Bit more complicated than that, especially with 2 strokes.
A 2 stroke is exhaust is designed to use pressure waves to bounce around and such the next lot of exhaust gas from the engine and the next lot of fresh mixture into the engine. It will do this well in a particular rev range. If you move that rev range further up so you produce peak torque at higher rpm then you produce more power (power is just torque * rpm, so for more power you need to produce more torque or just produce the same torque at higher revs).
| sunnyj58 |
| prawny1 |
 prawny1 World Chat Champion
| prawny1 |
| sunnyj58 |
| prawny1 |
| Nope. |
The last post was made 15 years, 6 days ago. Instead of replying here, would creating a new thread be more useful? |
