CM200 1982 Rebuild!
von1papen
PostPosted: 23:42 - 23 Mar 2011    Post subject: CM200 1982 Rebuild! Reply with quote
Ended up buying a nicely running example for 200 quid, engine sounds great, no bad rust or pitting anywhere (other than the normal surface rust in places), wiring lume is a tad bodged but it works!
Needs a fair few things replaced, chain sprockets some of the cables, brake shoes etc and I'll be re painting the frame, none of which is major imo!
Had to rip her to pieces for transportation back to my house as I'am in uni accom at the moment
von1papen
PostPosted: 00:17 - 03 Apr 2011    Post subject: Reply with quote
Frame and engine taken home, painted the frame and the various plates and stands etc that bolt on!
https://i1137.photobucket.com/albums/n512/von1papen/cm200001.jpg
https://i1137.photobucket.com/albums/n512/von1papen/cm200002.jpg
woll
PostPosted: 18:08 - 03 Apr 2011    Post subject: Reply with quote
Did you do any prep work on that frame?
von1papen
PostPosted: 01:38 - 04 Apr 2011    Post subject: Reply with quote
Lots of sand paper, wire brush plus a wire brush attachment and a drill! Can't honestly say that I got rid of all the older paint but any rust is gone.
There is a few unpainted patches seen in the photo which are done now, had to go over the frame several times to find various nooks n crannies I hadn't painted.
Not a picture perfect job I'll admit, getting it sand blasted and then spraying would of made a much cleaner job but tbh the tinned hammerite cost a tenner and will protect it just as much. (Uncle uses it for the bottom of land rovers that he restores so I know it'll protect the bike frame metal fine)
Not going to see the frame much either so again it doesn't particularly bother me, I was actually quite suprised how well most of it turned out! Reassembly will happen next weekend so I'll see what it all looks like then!
von1papen
PostPosted: 19:49 - 09 Apr 2011    Post subject: Reply with quote
Pieced most of her together today, runs and sounds lovely! Smile
Just needa attach speedo and wait till May when I can afford a new brake cable, chain and sprockets plus new oil n spark plugs! Sad
https://i1137.photobucket.com/albums/n512/von1papen/cm200003.jpg
https://i1137.photobucket.com/albums/n512/von1papen/cm200004.jpg
https://i1137.photobucket.com/albums/n512/von1papen/cm200005.jpg
https://i1137.photobucket.com/albums/n512/von1papen/cm200007.jpg
von1papen
PostPosted: 20:19 - 09 Apr 2011    Post subject: Reply with quote
Yeah its got that front brace with 4 bolts, a top bracket with 3 bolts and two main bolts into the centre of the frame!
von1papen
PostPosted: 20:34 - 09 Apr 2011    Post subject: Reply with quote
I have faith in its ability to hold its engine Very Happy
Namely because I went 100 miles on the CG without realizing that the top engine brackets had came off along with the nuts holding the bolts on and were sitting on top of the engine block.... yet stayed there the whole trip which was abit retarded! Laughing
The last post was made 15 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 64.8 Kb
