Aprilia rs125 powervalve
Daryl86
PostPosted: 14:26 - 10 Apr 2011    Post subject: Aprilia rs125 powervalve Reply with quote
Hi guys. Ive got an aprilia rs 125 with a very stuck powervalve. Ive managed to lever it out about 5 mm but it won't budge any further. I've even managed to snap a screwdriver so far.
I've tried to get it out after a long ride in the hope that a hot engine will help but no luck. Ive soaked in in wd40 for a day and also some other penetrating spray. Nothing.
I might try using a blowtorch to heat it up and see if that helps.
So has anyone got a magical solution on how to get it out or any other knowledge that might help?
Thanks, Daryl.
Damon
PostPosted: 14:54 - 10 Apr 2011    Post subject: Reply with quote
keep on with the wd40, petrol etc and it will eventually come out. Can you get something like a feeler gauge into the gap to try and free it up a bit?
The rs powervalves always stick, especially if they have been run rich Thumbs Up
Good luck
PostPosted: 21:39 - 10 Apr 2011    Post subject: Reply with quote
Possibly the least risky way (as the power valves have a habit of snapping) is to take the barrel off so you can carefully knock the valve out from below.
The last post was made 15 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 36.04 Kb
