cleaning a radiator????
billy_27
PostPosted: 20:50 - 10 Apr 2011    Post subject: cleaning a radiator???? Reply with quote
whats best way 2 clean the front fins on a radiator.the rad is from a ns 125(1991) model.its badly blocked and it needs cleaning in order for it to get air to cool it. no point buying second hand cos im sure it will have the same problem due to the age. cheers sean
PostPosted: 21:37 - 10 Apr 2011    Post subject: Reply with quote
Pull it off and pressure wash it from the back.
billy_27
PostPosted: 22:04 - 10 Apr 2011    Post subject: Reply with quote
will 2 much pressure damage the fins ?
Noxious89123
PostPosted: 23:35 - 10 Apr 2011    Post subject: Reply with quote
At a guess, I'd say yes.
heehaw
PostPosted: 00:18 - 11 Apr 2011    Post subject: Reply with quote
Give the inside a rinse while it's off.
Its important, otherwise it wouldn't be there.
Retro Rider Bicycles: CB125TDC, CBR400RR, BSA Bantam.
PostPosted: 00:54 - 11 Apr 2011    Post subject: Reply with quote
I usually just blow through mine with an airline, nothing more.
Before I had an airline, I brushed the bugs off with a soft bristled floor brush (the sort you'd be happy to brush down your paintwork with). The fins are bendier than they look.
Suntan Sid
PostPosted: 07:38 - 11 Apr 2011    Post subject: Reply with quote
I've recently done this on one of my bikes.
You don't need a pressure washer, tap water pressure should be enough, as long as you've got a proper nozzle/gun on the end of your hose!
And no it won't damage the cooling fins.
DrDonnyBrago
PostPosted: 08:25 - 11 Apr 2011    Post subject: Reply with quote
Did this on mine not long ago, hosepipe, bucket and allow wheel brush worked well. The trick is to let the filth soak for a while to soften up thenwork it out under running water with the brush.
The fins bend very easily.
When I did mine, I used high temperature paint on the header tanks, and diluted this paint considerably with thinners to paint the fins with, it means it goes on very thin and doesn't block the airways or add much insulative paint to the fins, totally optional of course but if your rad is looking a little knackered it is best to catch it early than it is to get it repaired/replaced when the corrosion is too bad.
The last post was made 15 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 56.45 Kb
