| Coming up to a corner, do you: |
| Grab clutch, downshift, let clutch out (repeat if necessary) |
28% |
[ 33 ] |
| Grab clutch, downshift, blip, let clutch out (repeat if necessary) |
56% |
[ 64 ] |
| Grab clutch, down two or so gears and as you apply the throttle let thbe clutch out |
14% |
[ 17 ] |
| Total Votes : 114 |
| HD |
 HD World Chat Champion
 Posted: 23:27 - 11 Apr 2011 Post subject: Downshifting Poll |
This is purely a thread just for the poll as I want to see the techniques used coming up to a corner. Not a traffic light or a junction where you are stopping but where you have to brake and go down at least a gear.
Thanks!
EDIT: Thought I put in an option for other but clearly I didn't fill it out properly. If you do none of the above please post a comment below and don't tick any of the boxes. ____________________ Rusty '02 Vito Camper + CBR600F3
| Nai |
 Nai World Chat Champion
 Posted: 23:32 - 11 Apr 2011 Post subject: |
Depends entirely on the corner and speed if I am honest... Not a very good poll answer  |
| HD |
| T0MMY |
 T0MMY World Chat Champion
 Posted: 23:34 - 11 Apr 2011 Post subject: |
I said option 2. Option 1 is fine generally but a throttle blip is obvously better for your transmission, reduces the weight shift and chance of locking the back wheel and of course, most importantly, sounds cool
Option 3...do you mean you're only reengaging the clutch as you start to apply a little throttle through the corner, i.e. once you're off the brakes and already starting to lean as that sounds like you're going to unbalance the bike pretty badly and give yourself a lot to think about in a short space of time. |
| binge |
 binge Emo Kiddy
| HD |
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 00:41 - 12 Apr 2011 Post subject: |
He who doth downshift without blipping ye olde throttle, shall face being hanged in front of the villagers!
In my eyes, downshifting without an appropriately measured out blip (depending on rate of deceleration) is just as bad as upshifting without letting off the throttle. 'tis the same principle; rev matching, clutch forgiving, smoothening out, better control. ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| whitedevil |
 whitedevil World Chat Champion
| HD |
| Ben. |
 Ben. World Chat Champion
 Posted: 01:15 - 12 Apr 2011 Post subject: |
free wheeling round corners means you have no engine braking to slow you down if you go in to hot, and you tend to speed up when you free wheel round corners.
You should have a neutral throttle mid corner, not accelerating but throttle should not be closed. This avoids the jerk when you want to get on the gas coming out of a corner whilst still lent over.
I blip but thats because i spend 90% of my biking life on a race track where it is needed, and thus becomes habit. However if your bike has a slipper clutch or quick shifter then you dont really need to blip.
Blipping helps avoid rear wheel lock up. On a track when the rear wheel is only skipping along the floor under heavy braking it is easy for it to lock up, also you are very high in the rev range. On the road you rarely brake that hard and are rarely that high in the rev range. It still helps but its not as vital on the road. ____________________ follow my racing season
Race bike - R6
Road bike - sv650 |
| hmmmnz |
 hmmmnz Super Spammer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 07:01 - 12 Apr 2011 Post subject: |
Dunno. Don't so much blip the throttle as slowly increase it as the clutch is let out. If I lose a few MPH in the process I'm not going to commit seppuku over it. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| The Tot |
 The Tot World Chat Champion
| stinkwheel |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 08:37 - 12 Apr 2011 Post subject: |
2 Smoke
If I’m out on the 250 NSR, I’ll be on the brakes a lot.
Approaching a good bend, I’ll be hard on the brakes, and down shifting to keep the motor spinning.
Once into the corner, I’ll be slipping the clutch, a lot, and keeping the revs up,
Once I’ve hit the apex it’ll be full throttle, if I’ve dropped out of the powerband there will have to be more clutch slip until I hit it, then its clutch out and away we go.
IL4
Got to say if I’m out on the CBR6, unless I’m in hooligan mode, I very rarely use the brakes with any great force.
If it’s a road I know, I will be matching revs and using engine braking to slow down.
I will be using the clutch and throttle blipping to match the revs before I tip it into the corner. Once into the bend I’ll be feathering the throttle up to the apex, once I’ve hit the apex I’ll get, smoothly, on the power to exit the corner.
Big Single
Leave it in fourth!  ____________________ "Everybody needs money, that's why they call it money!"  |
| FBSF |
 FBSF Nitrous Nuisance
| Kickstart |
 Kickstart The Oracle
| supZ |
 supZ World Chat Champion
| supZ |
| HD |
 Posted: 10:40 - 12 Apr 2011 Post subject: |
Hmmmmmmmnz, TOT and supZ, that is what I meant by the second option.
Keith, I know. I don't do it just saying people do.
And supZ, I generally mean junction where you just brake and go, not stop if you get me. Hard to explain... ____________________ Rusty '02 Vito Camper + CBR600F3 |
| CarlosCBR |
 CarlosCBR World Chat Champion
| Jim Mc |
 Jim Mc Nearly there...
| Kickstart |
| HD |
| Paxovasa |
 Paxovasa World Chat Champion
The last post was made 15 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
