tzr 125 clutch stuck
hornetmike
PostPosted: 09:04 - 14 Apr 2011    Post subject: tzr 125 clutch stuck Reply with quote
hi i recently bought a tzr 125 that has been stood for 3 years it starts and runs fine but the clutch wont disengage can anyone tell me the best and easyest way to free it off
thanks mike
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
truslack
PostPosted: 09:33 - 14 Apr 2011    Post subject: Reply with quote
Make sure all the adjusters are set correctly, then push the bike along in 1st gear with the clutch held in - rock it forwards and backwards and it should free off. It may be easier to do this with the engine warm.
PostPosted: 09:45 - 14 Apr 2011    Post subject: Re: tzr 125 clutch stuck Reply with quote
thanks mike
Have you changed the gearbox oil? That would be a good first step.
dextersaurus
PostPosted: 09:49 - 14 Apr 2011    Post subject: Reply with quote
front tyre up against a wall, hold front brake, give it some welly and dump it into 1st gear Wink
At least that's how i freed off the clutch on the GPZ.
Dunc
truslack
PostPosted: 09:55 - 14 Apr 2011    Post subject: Reply with quote
Dunc
I did this with a Supedream, but held the back brake on instead of tyre against a wall... it destroyed the gearbox.
PostPosted: 10:10 - 14 Apr 2011    Post subject: Reply with quote
Why have I got a "Troll Science" type cartoon in my mind?
Stuck clutch? Find a Bro. Get bro to hold on back brake (possibly using magnets) Rev engine.
Gearbox Problem?
truslack
PostPosted: 10:13 - 14 Apr 2011    Post subject: Reply with quote
Gearbox Problem?
In theory it should have worked Laughing
dextersaurus
PostPosted: 10:36 - 14 Apr 2011    Post subject: Reply with quote
https://i624.photobucket.com/albums/tt325/duncdmc/Untitled-2.png?t=1302777393
Edit: WTF? HOW?
Balls, forgot about the gearbox bit.
See attached
Frost
PostPosted: 10:48 - 14 Apr 2011    Post subject: Reply with quote
Surely a stuck clutch is most likely due to badly adjusted cables. If thats not the reason then it's plates that have bonded tot he steels with manky old oil, or rusted to the steels. It might even be spring or actuator related. Either way The clutch cover needs to be removed and the whole lot taken a look at. You might get away with just taking it apart to free things up and putting it back together again. Or you might need new friction plates, steels and to scrub and rinse a load of shitty oil out of it.
0l0dom0l0
PostPosted: 10:58 - 14 Apr 2011    Post subject: Reply with quote
Roll it along at about 5 mph, dump it into first, then drive along a bit and slowly bring the bike to a stop with the clutch pulled in and the revs up. Should free it.
If not then as frosty said the clutch plates will probably have stuck together.
FBSF
PostPosted: 11:08 - 14 Apr 2011    Post subject: Reply with quote
What he said - it will only take half hour or so to drain the oil, take it apart, clean the plates with kitchen roll, put it all back together with new oil. You'll also see if any of the non-friction plates are bent which could be causing it.
The Artist
PostPosted: 11:13 - 14 Apr 2011    Post subject: Reply with quote
What has been said before. My bikes plates stick after 3 days.
I just start it, get it rolling in 1st and let the clutch out then slowly brake but keep revving and the slower I go the more force through the clutch and it frees up.
The last post was made 14 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 74.55 Kb
