| Eirkir |
 Eirkir L Plate Warrior
 Posted: 16:45 - 14 Apr 2011 Post subject: Project and MOT. Any problems at all? |
Hi guys. I'm new in this country (I came from Germany) and I don't exactly know an MOT requirements yet. I have the bike and car and of course did an MOT this year but thats it
I do sme project and I have few question:
Can i meet some problems when I'll take my project-bike to MOT station?
It is Yamaha XTZ660 with Suzuki GS500 wheels. Rear brake is form new 2009 XT660X. Bike is done with good bike rules understanding and every part has been chosen carefully.
Bike has different petrol tank from XT600 model. Road legal twin-headlights and indicators.
At the moment has no clocks and I consider to put some Acewell or Trail Tech clock but I dont know there are road legal... etc... etc... etc...
Can I have some advice from experienced mates?
Thank you guys, Eirkir |
| Moo. |
 Moo. World Chat Champion
 Posted: 17:03 - 14 Apr 2011 Post subject: |
It doesnt matter what its made up of, the MOT is to make sure the vehicle is road worthy, so legal lights, legal tyres, needs clocks, check that nothings rotten through with rust, all electrics work (horn etc..).
Can remember if mirrors are a legal requirement but as long as its all in good condition and works as it should, you'll be fine
Remember all the small things aswell like split pins and dashboard lights as you can pick up advisors for these.
If your fitting brakes, make sure they all work properly as there is a brake test, check bearings too, some have allowances for play, but you'll have to check the manuals.
I should think most clocks are legal, because you can get an mot pass on a bicycle computer clock fitted (£10 from halfords or somewhere like that) As long as it tells you your speed i think.. someone shall correct me if im wrong  ____________________ A2 Passed 18/6/10 |
| truslack |
 truslack World Chat Champion
 Posted: 17:10 - 14 Apr 2011 Post subject: |
Speedo isn't a problem - you don't need one for MOT. To use on the road, the speedo must be illuminated when the front position light (sidelight) is lit IIRC.
Rest of the stuff shouldn't be a worry, MOT testers guide is here:
https://www.motuk.co.uk/manual/mc_contents.htm ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| stinkwheel |
 Posted: 17:12 - 14 Apr 2011 Post subject: |
It's not like Germany whwere you have to have a piece of paper from the TUV for every little thing.
If the parts are properly attached and work as they should do, it's fine. You are supposed to tell your insurance company about any modifications.
I'm not sure about the clocks. They are definately not tested as part of the MOT (so they don't have to work) but it is possible they might have to be present. In which case you could just bolt any old set of clocks to it and not connect them up.
You have to have a hi-beam warning light and you have to have an indicator repeater light if you can't see the front indicators from the saddle.
More seriously altered machines are supposed to be put through a Single Vehicle Approval (SVA) test but simply changing the wheels and petrol tank isn't enough to trigger this. That's more for if you chop the frame and suchlike, it's based on a points system. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kickstart |
 Kickstart The Oracle
| Eirkir |
 Posted: 08:11 - 15 Apr 2011 Post subject: |
Thank you guys It helped me a lot  |
| sickpup |
 sickpup Old Timer
| Frost |
 Frost World Chat Champion
| Kickstart |
| tvchimp |
 tvchimp World Chat Champion
The last post was made 15 years, 91 days ago. Instead of replying here, would creating a new thread be more useful? |
