Is this the Ignition coil....?
Wyldkat
PostPosted: 19:38 - 14 Apr 2011    Post subject: Is this the Ignition coil....? Reply with quote
Hi, quick one (hopefully)
I've got an Old Suzy GP100, D plate.
This is the sequence of problems - I think it's the Ignition Coil...
Neutral light was very dim and Flashed in sequence with the Indicators when on, eventually stopped working;
Headlamp also flashed in sequence to Indicators;
Indicators only worked when revved high....
First thought it was either the Earthing or the Rectifier
Have checked all the wiring, had to patch a few things up and now all lights work fine (except the Neutral Bulb!) so not the Rectifier or Earth connections.
Tried to kick it over and I have no spark at Plug, changed plugs and still nothing but lights still remain fine so not Battery or Rectifier....
Stuck!
Any ideas?
Thank you
Wyldkat
PostPosted: 22:08 - 14 Apr 2011    Post subject: Reply with quote
...pass for now. Not too sure, will check the bible
Wyldkat
PostPosted: 21:24 - 20 Apr 2011    Post subject: Reply with quote
update - it's a nippon condensor!
Cant get the bloody thing off now, too much rust!
The last post was made 15 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 40.47 Kb
