| SpannerMonkey |
 SpannerMonkey World Chat Champion
 Posted: 16:49 - 18 Apr 2011 Post subject: |
You might find quite a few C50 gaskets will fit it. I'd order a full C50 gasket set and see (worth a gamble at a tenner). That'll have head and base gaskets, valve stem oil seals and various o-rings. I really wouldn't use an old head gasket unless it is totally impossable to get hold of one and you shouldn't really need gasket compound either there or on the base gasket. Another option is to get a new one cut out of copper sheet.
If the valve seats are clean, leave them alone. If there are signs of leaking/pitting/scorching, lap them in yourself. Not difficult, just time consuming.
I'd also just check the bore. You sit a new ring square in the bore (push it in with the piston) and measure the end-gap with feeler guages. There will be a maximum size for this gap. If you're under it, hone and replace rings. If you're over it, rebore.
From your description, valve stem oil seals will be the one thing you must make sure to do. Don't replace engine bearings for the sake of it, some of them are a total pain to remove and then source new ones. If they've been sat in oil, they're probably ok. I reckon at most I'd do the mains and small ends, possibly the clutch.
If you can't get a base gasket, cut one out of the back of a cornflakes packet. This works well.
Go easy on the gasket sealant, you don't need to use it in most places. If you have a workshop manual, it should tell you where to use it and just use it very sparingly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| SpannerMonkey |
| 27cows |
 27cows World Chat Champion
| SpannerMonkey |
| prawny1 |
 prawny1 World Chat Champion
| SpannerMonkey |
The last post was made 14 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
