Problem
983fj7t
PostPosted: 15:48 - 18 Apr 2011    Post subject: Problem Reply with quote
Hey, I got on my moped this morning and it would not start called the RAC, He came put new spark plug in and check compression and spark all was right but , no joy starting it. It wants to tick over and t tries. There is what it seems to be is glitter in the fuel tank on the bottom he said.
Any one help
Rieju RS2 50cc - Proud Owner !
https://i73.photobucket.com/albums/i233/Fletchera/ant.gif
983fj7t
PostPosted: 17:38 - 18 Apr 2011    Post subject: Reply with quote
any one ?
Quote Me Happy
PostPosted: 17:41 - 18 Apr 2011    Post subject: Reply with quote
Sounds like crud in your tank has made its way into the carb causing a blockage. You'll need to clean your carb making sure the jets are clear and clean the crud from your tank.
CaNsA
Take the tank off, clean it out, replace your filter
jimbothe
Did you take it out on the piss to a club?
Any chance someone has put something in there for a joke?
You need to take the tank off and drain it first, then put a little more clean petrol in and swill it around before draining it again. Check it to see if it's all clear. Chances are you will need to drain the pipes and the carb as well.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
983fj7t
PostPosted: 18:01 - 18 Apr 2011    Post subject: Reply with quote
What can i clean the carb out with ? im new to this.
jimbothe
PostPosted: 18:09 - 18 Apr 2011    Post subject: Reply with quote
Carb cleaner Thumbs Up
SpannerMonkey
PostPosted: 18:11 - 18 Apr 2011    Post subject: Reply with quote
This, And fresh petrol too! What moped is it?
EDIT: Just seen your sig, Reiju RS2 I take it? Smile
My bike? A YX140 powered one-off Monkey Bike, something a little different!
jimbothe
PostPosted: 18:13 - 18 Apr 2011    Post subject: Reply with quote
Pop into your local motor factors or halfords etc, whatever you have near you.
I use this
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_202903_langId_-1_categoryId_165750
Simply because Halfords is just round the corner but they are all much the same.
983fj7t
PostPosted: 18:26 - 18 Apr 2011    Post subject: Reply with quote
oop's i need to edit my sig, Its a MBK Nitro 50cc
Carb Cleaner Smile could of thought of that.
983fj7t
PostPosted: 18:29 - 18 Apr 2011    Post subject: Reply with quote
can any biker help me in reddish stockport ? take me fuel station
SpannerMonkey
PostPosted: 18:33 - 18 Apr 2011    Post subject: Reply with quote
Oh yeah, I've worked on loads of them, Same as the yamaha aerox. Normally they have an inline fuelfilter (Well, all the ones I've worked on have) Rinse your fuel tank out with fresh petrol and replace the filter if you know how to Smile
The last post was made 14 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 71.97 Kb
