Battery question
marcelthegrea...
PostPosted: 13:13 - 20 Apr 2011    Post subject: Battery question Reply with quote
Would a 6.5 amp battery work on a 4.5 amp bike?? Would it cause any problems? Thanks.
PostPosted: 13:19 - 20 Apr 2011    Post subject: Reply with quote
AFAIK the AMP the amount of charge you have in a battery each electrical component will draw the required amount.
i.e. you might need 0.5 amps to have your indicators flashing and 2 amps for your headlight. Therefore your battery could power your indicators for 4 times longer than your headlight.
I think it would be fine, and it would last longer too.
But let somebody in the know confirm I could be completely wrong.
DrDonnyBrago
PostPosted: 13:24 - 20 Apr 2011    Post subject: Reply with quote
Components only draw as much current (amps) as they need, the battery will be rated in Ah (i.e. amps x hours) and means how much charge they will hold. Personally I'd stick with the standard spec battery.
Teflon-Mike
tl;dr
PostPosted: 14:04 - 20 Apr 2011    Post subject: Reply with quote
if it physically fits... is the first question.
after that, should work fine.
just stores more charge, so it will take longer to charge up, and longer to go flat.
BIG question though is the cranking amps and other rates.
Basically three grades of lead accid battery.
- Deep Cycle
- Standard Car
- Leisure / Alarm
Capacity of each can be the same, but its thier tolerence to rapid discharging that makes the difference.
Leisure / alarm batteries have very big reserves, but expect a very long draw rate, alarms for instance powering no more than an LED until triggered.
Car battery is expected to deliver a bit more, powering lights, radio & equipment, BUT BIG draw when you start the engine from the starter motor. Starter motor can take completely charged 90Ah battery, and flatten it in perhaps ten minutes continiouse cranking.... doing that repeatedly would 'kill' the battery very quickly.
Hence 'Deep Cycle' batteries which are used for things like winches and high power devices that take lots of amps very quickly, and get charged just as quick, repeatedly, and would 'kill' normal batteries.
SO.... bigger battery would be fine, but if it is a leisure battery or alarm battery that doesn't have the cranking amps capability you need, every time you start the engine, you'll suck the battery dry and 'tire' the plates in it, which will kill it quite quickly.
so if it pysically fits, and has cranking amps, should be OK.
finpos
PostPosted: 20:57 - 20 Apr 2011    Post subject: Reply with quote
Will do no harm. Since I've had money, I've stuffed the highest rated battery I could possibly find and that would fit into anything I've owned. This saves an enormous amount of grief.
f.
The last post was made 15 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 45.27 Kb
