| Mellow Matt |
 Mellow Matt Scooby Slapper
 Posted: 18:22 - 20 Apr 2011 Post subject: Brake Judder |
My TLR's front brake judders a fair amount, and it's particularly noticeable at low speeds where the brakes will be on then off repeatedly if the lever is held in slightly at a walking pace.
I swapped the discs over with some I got 2nd hand and tested it out and the judder had gone, but now it seems to have come back again after 100miles or so
I haven't been braking hard at all, and haven't abused the discs/pads. As far as I'm aware it can only really be the discs or bearings (I know nothing about bearings though!) causing it, but I don't really know how to tell (especially since I don't have too many tools, and can't really get the front wheel off the ground!).
I've just taken the calipers apart to have a check - the pistons all move fairly freely, although when squeezing the brake one piston seems to come out first (I don't think that matters though). The pads are fairly evenly worn and nothing looks awry with them.
Does anyone have any ideas what it would be or how to stop it?
Thanks! ____________________ 1999 GSX-R 600, 1999 TL1000R |
| jimbothe |
 jimbothe World Chat Champion
 Posted: 18:50 - 20 Apr 2011 Post subject: |
Hi there, just a thought but have you checked the head stock bearings? This can cause judder under braking as well. ____________________ Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle |
| Mellow Matt |
| SpannerMonkey |
 SpannerMonkey World Chat Champion
| jimbothe |
| Mellow Matt |
| jimbothe |
| Mellow Matt |
 Posted: 21:09 - 20 Apr 2011 Post subject: |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 23:23 - 21 Apr 2011 Post subject: |
Try cleaning the discs with some brake cleaner. I found this helped with brake judder on my CBR. I was in the same situation as you. Swapped the discs, it went away only to soon return. When the pads / discs get warm, some of the brake pad material can transfer onto the discs. If this transfer is uneven you can get this juddering.
I found that if I cleaned the discs, it would go away for a short while. The thing is, it doesn't always do it. Sometimes you'll stop and it'll be fine, others it will judder when you slow down below about 20mph.
I just live with it tbh, as it isn't that bad.
EDIT: Also, I can confirm that my front wheel bearings are fine, head bearings have been replaced with new ones, forks have had new seals bushes and oil (as well as having the stanchions polished to remove pitting) tyre is good, and the discs and pads themselves aren't that old. Brake hoses and fluid are new too.
Old ones were OEM and juddered. New ones are EBC and still do it. Brakes have been stripped and rebuilt, and since have been cleaned on many occasions, and they still do it!
If you find a solution, I'll be pleased to hear it. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| Mellow Matt |
 Posted: 17:58 - 26 Apr 2011 Post subject: |
| Noxious89123 wrote: | Try cleaning the discs with some brake cleaner. I found this helped with brake judder on my CBR. I was in the same situation as you. Swapped the discs, it went away only to soon return. When the pads / discs get warm, some of the brake pad material can transfer onto the discs. If this transfer is uneven you can get this juddering.
If you find a solution, I'll be pleased to hear it. |
Thanks for the info mate. I had tried cleaning the discs, but it didn't seem to make any difference. I also got it up on a stand and tested the bearings, but they seem ok.
I've discovered that the TL's front wheel and discs are the same size as my GSXR600, so I've swapped the wheels over and the judder has gone for now. I'm going to keep using it and see if the judder comes back - if it does it must be something to do with the pads/calipers/forks I guess... ____________________ 1999 GSX-R 600, 1999 TL1000R |
| Noxious89123 |
The last post was made 15 years, 72 days ago. Instead of replying here, would creating a new thread be more useful? |
