Ultrasonic Carb Cleaning
 Topic moved: from General Bike Chat to The Workshop by Korn (16 Aug 2004 - 18:51)
rizo-sri200
PostPosted: 19:24 - 16 Aug 2004    Post subject: Ultrasonic Carb Cleaning Reply with quote
Has anyone heard of this ^?
Its just that i can get it done for free.....
Is it worth doing?
Thanks
Jon Wink
swift kick to the wing mirror puts em straight..
98' Bandit 600 with Slip on
PostPosted: 19:29 - 16 Aug 2004    Post subject: Reply with quote
Heard of it being done with fuel injectors but not found anyone doing it for carbs.
Probably worth doing if they are getting old and a bit gummed up.
Claud 14.7 to 1
PostPosted: 19:36 - 16 Aug 2004    Post subject: Reply with quote
What is it exactly? Sound like one type of "wave" used to zap crap out of carbs, not needing to open them up...? Surely not.
rizo-sri200
PostPosted: 19:41 - 16 Aug 2004    Post subject: Reply with quote
they are stripped of jets, floats, choke and bowl etc and placed in a tank that passes ultrasonic wave through them
Using an ultrasonic cleaner will allow non-profitable time spent scrubbing gummed-up float bowls and jets etc. to be utilised performing more productive tasks. Ultrasonic cleaning works by a process known as cavitation where high frequency sound waves cause microscopic bubbles to form which then violently collapse releasing energy many times greater than that of mechanical brushing. This process will not damage or scratch the surface being cleaned and will effectively remove petrol deposits from float needles, pilot jets etc, with no physical scrubbing required. Another distinct advantage of cleaning with ultrasonics is the speed of operation - often just one hour is adequate, depending on the amount of build up.
Claud 14.7 to 1
PostPosted: 19:45 - 16 Aug 2004    Post subject: Reply with quote
Thanking you. Thumbs Up
rizo-sri200
PostPosted: 20:00 - 16 Aug 2004    Post subject: Reply with quote
More Knowledgable day by day Thumbs Up Mr. Green
kev
I Hump Things
PostPosted: 21:17 - 16 Aug 2004    Post subject: Reply with quote
If its free do it. Thumbs Up
I belive they use the same process in tattooing for cleaning the bits they use.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
rizo-sri200
PostPosted: 21:22 - 16 Aug 2004    Post subject: Reply with quote
I may have a problem?
While stripping down the carbs for the ultrasonic cleaning tomorrow i noticed on one of my mixture screws that the point is missing.... is this bad?
kev
I Hump Things
PostPosted: 21:44 - 16 Aug 2004    Post subject: Reply with quote
Yes, get a new one.
rizo-sri200
PostPosted: 21:46 - 16 Aug 2004    Post subject: Reply with quote
are they expensive? also where is the little point?
i cant believe how dirty my carbs are... ugrhhh Sick
Big Pete
PostPosted: 09:14 - 17 Aug 2004    Post subject: Reply with quote
they aren`t usually expensive, the point is probably jammed in the jet the screw runs into.
Trust me, I`m an engineer
GarageOfPower.co.uk
rizo-sri200
PostPosted: 20:55 - 17 Aug 2004    Post subject: Reply with quote
Big pete: your right, the end of the needle is jammed in the jet..
Cant get the bugger out Evil or Very Mad
200psi air line wont even touch it Crying or Very sad
Any ideas how or if to remove it??
Also 2nd hand carbs, where?
rizo-sri200
PostPosted: 21:17 - 18 Aug 2004    Post subject: Reply with quote
and a new carb is £325
Robby This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
baldy
PostPosted: 00:05 - 19 Aug 2004    Post subject: Reply with quote
If it still works, leave it jammed in there. Maybe the ultrasonic carb cleaning will loosen it.
Oh yeah, when I put any screw into cast aluminium, I put a little copper grease on. Stops them from seizing in. Thumbs Up
One day i will rule the world, just not today.
Big Pete
PostPosted: 11:11 - 19 Aug 2004    Post subject: Reply with quote
on the last on I had to do (ham fisted twat of a previous owner) the jet went into the carb bore so I could push the broken point out out with the tip of a screwdriver. On some carbs the jet itself will unscrew/push out which would allow you to either get the point out or replace the jet.
Last nut not least, some gentle heat followed by the airline might do it. Good luck. Thumbs Up
PS what bike is it?
GarageOfPower.co.uk
rizo-sri200
PostPosted: 18:25 - 19 Aug 2004    Post subject: Reply with quote
Honda CB-1
Model: CB400F NC27
katana
PostPosted: 10:05 - 21 Aug 2004    Post subject: Reply with quote
robby wrote:
ahh the joys of owning obscure grey import 400s.
Cheap for a very good reason they are.
I hate to break the myth but 400 are not cheap they are interesting to have fun on I got and import suzuki and can get most parts from either suzuki main dealer or suzuki direct from japan.
CB1 is quite common so spares from a 400 specialist should not be a problem.
Raff
ZRX61
Victor Meldrew
PostPosted: 00:15 - 26 Aug 2004    Post subject: Reply with quote
Jon, Ignore baldy's post... PLEASE!
The idea of this forum is surely to get advice from people who know WTF they are talking about.. any pillock who leaves a needle tip jammed into a carb jet needs his nipples tuned with a pair of pliers.
The last post was made 21 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.66 - MySQL Queries: 16 - Page Size: 102.3 Kb
