Honda NSR 125 Flat/Dead Spot 7000rpm
clewlow690
PostPosted: 10:56 - 26 Apr 2011    Post subject: Honda NSR 125 Flat/Dead Spot 7000rpm Reply with quote
Hi as with the subject my nsr has developed a huge dead spot at 7000rpm mainly in 5th and 6th gear. Has anyone any ideas why? Cheers!
DrDonnyBrago
PostPosted: 11:29 - 26 Apr 2011    Post subject: Re: Honda NSR 125 Flat/Dead Spot 7000rpm Reply with quote
Does it have an aftermarket exhaust or air filter (or even worse a cone filter)?
Is the exhaust blowing?
Air leak around the carbs making it run lean?
Could be a few things, if you have recently had the exhaust or carbs off I'd start there.
Ethan
PostPosted: 11:46 - 26 Apr 2011    Post subject: Reply with quote
Isn't the powervalve suppose to open at around 7-8000 rpm?
Check that for gunk etvc
clewlow690
PostPosted: 13:42 - 26 Apr 2011    Post subject: Reply with quote
yh its got a sports exhaust on but no other modifications. The exhaust was on when I brought it. Its only developed this problem in the last week or so it was running fine before that. When I try and open it up at 7000rpm it just seems to die as if its running out of petrol or something. Cheers!
dextersaurus
PostPosted: 14:38 - 26 Apr 2011    Post subject: Reply with quote
Running rich/lean?
Try replacing the spark plug, easiest and cheapest solution Laughing
Dunc
The last post was made 15 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 43 Kb
