Ok, now i could do with some Experts.
BikerGuy95
PostPosted: 21:47 - 27 Apr 2011    Post subject: Ok, now i could do with some Experts. Reply with quote
Ok, so about 2 months ago, it turned out my squeak on my DNA was my wheel bearings. i got them changed and now they're squeaking again.
How often do wheel bearings pop? Sad
CBT Passed: 24th February 2011 Very Happy
Nope.
PostPosted: 21:53 - 27 Apr 2011    Post subject: Reply with quote
Not very often if they are put in correctly and the wheel is aligned correctly. If they were hammered in rather then pulled it can shorten the life.
BikerGuy95
PostPosted: 22:14 - 27 Apr 2011    Post subject: Reply with quote
Well i got it done by a certified motorbike mechanic at his own garage... it cost me £80
prawny1
PostPosted: 22:18 - 27 Apr 2011    Post subject: Reply with quote
are you talking front or rear bearings?
hellkat wrote:
Nope.
PostPosted: 22:20 - 27 Apr 2011    Post subject: Reply with quote
Good point. I assumed front.
BikerGuy95
Thats what i aint sure of. i got the front ones replaced but this time i cannot tell if its coming from the front or the back, im pretty sure its the front though...
Raffles
PostPosted: 22:21 - 27 Apr 2011    Post subject: Reply with quote
Also depends on whether they were decent quality bearings or cheapshit items churned out in a sweatshop in China.
Frost
PostPosted: 22:24 - 27 Apr 2011    Post subject: Reply with quote
You sure it's not the brakes rubbing?
Put it on the centre stand and stick something heavy on the back to get the front wheel off the ground and see how easily it spins after you've applied the brakes. Repeat with the front caliper off and see if the squeek disappears.
prawny1
PostPosted: 22:29 - 27 Apr 2011    Post subject: Reply with quote
If you are sure it's the front again take it back to the guy that fitted the bearings.
A couple of months is a short life for wheel bearings.
BikerGuy95
PostPosted: 22:30 - 27 Apr 2011    Post subject: Reply with quote
I've done all that before and my front pads do slightly touch but they aren't causing the squeaking, they cant be...
cb1rocket
PostPosted: 22:34 - 27 Apr 2011    Post subject: Reply with quote
if they are rubbing they will squeak! You should see a small amount of gap between the pad and disc, very small gap mind.
Check the wheel for play in the bearing, if they are the bearings are shot!
BikerGuy95
PostPosted: 22:36 - 27 Apr 2011    Post subject: Reply with quote
I'll check all that tomorrow and get back to you on that.
Frost
PostPosted: 12:34 - 28 Apr 2011    Post subject: Reply with quote
Buy some copper grease and slap it all over the back of the brake pads. Stops them sticking, corroding and squeeking.
The last post was made 14 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 76.04 Kb
