| cb1rocket |
 cb1rocket World Chat Champion
| cb1rocket |
| Codemonkey |
 Codemonkey Crazy Courier
| cb1rocket |
 Posted: 22:28 - 27 Apr 2011 Post subject: |
| Codemonkey wrote: | RCD's work by detecting a difference in the current flowing in the live and neutral conductors. Normally, they should be the same. If however a fault condition occurs and some of the current is able to take a different path to the return (via earth which is connected to neutral at the substation), then the trip will activate.
In a system with an inverter, unless the neutral has been connected to earth (unlikely), then there are not many fault conditions that could allow the fault current to return to neutral via another path.
In short, I don't think fitting an RCD will have any effect unless your inverter has its neutral output connected to earth. Since it is probably not the case, you could probably touch the live conductor and not get a shock (don't try it though!!) since there is no return path for the current back to the inverter's neutral connection. |
thats what I have seen numerous times during my research with a lot of arguments for and against. Since you say you could touch the live and not get a shock if there was no return for the earth, you wouldn't get electrocuted. Problem there is that I have never belive that to be the case. If there is a live that is touched and there is nothing else for the current to return to, it will use your body as the earth and kill you?! But some say you won't get a shock followed by don't try this at home! typical lol
I know how an RCD works but looking at circuit diagrams, it doesn't rely on the earth, only the imbalance on the return current different ie 30mA then it trips. |
| Pete. |
 Pete. Super Spammer
 Posted: 07:56 - 28 Apr 2011 Post subject: |
Sounds like you are going way over the top. The easiest way to make sure no current can be tranferred from light to metal beam is to hang the light from the beam using something non-conductive instead of screwing it on directly.
Personally, I would use your setup without hesitation. I'd fix the light to the ceiling and make a shelf about waist height by the door to sit the battery on, screw the inverter on the wall above the shelf, at about face height, and hang the leads with battery terminals down to the shelf so I could walk through the door with a fully-charged battery, plonk it on the shelf and drop the power leads straight on the terminals. Job done. ____________________ a.k.a 'Geri'
| cb1rocket |
 Posted: 09:30 - 28 Apr 2011 Post subject: |
thanks Pete, also is the RCD more than sufficient? Thats what nobody seems to be able to answer. Thanks for the set up idea, mine is a system with a solar panel on the roof, therefore the battery stays put while being topped up during the sunny days. The shed is only used occasionally along with an 85Ah leisure battery.
The tube light in the shed is the best bit, as its super fecking bright, just what i wanted
Might upgrade the inverter for power tools and the like. |
| Pete. |
 Pete. Super Spammer
 Posted: 09:43 - 28 Apr 2011 Post subject: |
Yeah I think the RCD would be fine. Personally, I wouldn't have bothered even with that - I'd just fuse the striplight correctly.
I don't think you'll get far trying to run power tools off an inverter. Say you had a 1000w drill - that would pull at least 83 amps out of the battery.
Better off sticking to using it for lighting, and use battery powered tools, gas powered soldering iron that can double as a heat gun, old calorgas fire for heating etc or buy a cheap small silenced genny that you can heave outside if you really have to for 240v power. ____________________ a.k.a 'Geri'
| cb1rocket |
| kramdra |
 kramdra World Chat Champion
| cb1rocket |
The last post was made 14 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
